Go to Post Most of our old robots have been scrapped for parts. Our Chairman submissions are still read every year by the whole team. - N7UJJ [more]
Unread 04-02-2013, 19:22
avanboekel's Avatar
avanboekel avanboekel is offline
AKA: Adam Van Boekel
FRC #5934 (Gear it Forward, Crowbotics)
avanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant future
How do you attach tread to VEX traction wheel?
How are teams attaching tread to the VEX traction wheels? There are no rivet holes, or other obvious ways to attach it. Are we supposed to drill our own holes?
Thanks in advance!
Adam
2338 Gear It Forward | Student 2010-2013 | Mentor 2014-Present | oswegofirst.org
2013 Wisconsin Regional Winner (1732, 111, 2338)
2013 Midwest Regional Dean's List Finalist
2015 Midwest Regional Chairman's Award Winner
2015 Archimedes Subdivision Winner (1023, 2338, 3996, 1089)
2016 Midwest Regional Chairman's Award Winner
4096 CTRL-Z | Mentor 2014 | team4096.org
5934 Crowbotics | Mentor 2016-Present | crowbotics.org
Unread 04-02-2013, 20:00
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
Re: How do you attach tread to VEX traction wheel?
We successfully drilled our own rivet holes into the wheels.
Unread 04-02-2013, 21:22
avanboekel's Avatar
Where did you drill the rivet holes? There are hills and valleys on the wheel, and we weren't sure how exactly to do it.
Unread 04-02-2013, 21:49
vic burg's Avatar
vic burg vic burg is offline
Alumni, Mentor, & AmeriCorps VISTA
AKA: Captain Obvious
vic burg is a splendid one to beholdvic burg is a splendid one to beholdvic burg is a splendid one to beholdvic burg is a splendid one to beholdvic burg is a splendid one to beholdvic burg is a splendid one to beholdvic burg is a splendid one to behold
You can drill your own holes or if you feel like doing it a slightly messier way, you can always glue but rivets/screws are the best option.
RoboColts--Hallandale Elementary
--Thanks goes out to Cody C for making me ^^this^^ user bar!!!!
Nuts and Bolts help the world go 'round.... They also keep us all together. Including the Robots we build. -vic burg
I have been dubbed an honorary member of 1902 and 744 (by the members).
And yes, I am in the habit of collecting team t-shirts.
Unread 04-02-2013, 22:53
Shu Shu is offline
FRC #2137 (TORC)
Shu is an unknown quantity at this point
We used the AndyMark alligator clips. They seem to be holding up pretty well so far with our limited driving. We made the treads really snug and we are not seeing any slipping on the wheel. If necessary, we will add some rivets.
Unread 05-02-2013, 03:57
Bstep's Avatar
Bstep Bstep is offline
FRC #1983 (Skunkworks Robotics)
Bstep is a glorious beacon of lightBstep is a glorious beacon of lightBstep is a glorious beacon of lightBstep is a glorious beacon of lightBstep is a glorious beacon of lightBstep is a glorious beacon of light
We attach them by cutting the two ends of the tread at angles that mesh together. Then you can fit more rivets than just the width of the wheel. We contacted Vex and they said that it doesn't matter whether a rivet is placed on a "hill" or "valley."
Unread 05-02-2013, 08:05
Robogineer1649's Avatar
Robogineer1649 Robogineer1649 is offline
AKA: Adam Molnar
FRC #1649 (E.M.S.)
Team Role: Driver
Robogineer1649 will become famous soon enough
I was in charge of attaching the tire treads and i drilled my own rivet holes the only issue i had was keeping the tire tread tight round the wheel so watch out for that. I had to redo it multiple times.
Unread 05-02-2013, 11:25
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Hi Adam,
Last fall I experimented with a few things including rivets, self-tapping plastic screws, and glue. The best results involved large-head 1/8" rivets (they are available from places like McMaster, and we sell a pack here: http://www.vexrobotics.com/217-0396.html).
My preferred method is as follows...
I cut the tread to size (if you feel fancy, make it so the seam is a "/" which is at an angle not parallel to the wheel axis), then zip-tied the tread in place. Once in place, I drilled my rivet holes, 3x on each side of the seam, and then installed my rivets. It did not seem to make a difference if the rivets fell on the high or low parts of the "toothed" wheel rim as long as I made sure I had good engagement. The quality of the seam is everything -- spend time figuring out the size of the tread you want, and cutting it to shape. That is a mistake my team frequently makes over the years, we've found that by spending more time on the seam we're much happier with the result.
Some people will also sprinkle rivets along the outside of the wheel periodically, but I'm a big believer in the "if you pull the tread tight so it can't bunch up, and you get a good seam attachment, you don't need to do this" method.
Your Mileage May Vary... I hope you're season is going well so far!
Good luck.
-John
