Go to Post A dedicated team is a happy team. - sgreco [more]
Unread 05-02-2013, 04:52
Someone told me there was food here
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
pic: 2495 Teaser
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Re: pic: 2495 Teaser
Rivets are your friends.
Some 3/16 rivets would save some weight, and in our testing be more then enough to hold it all.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 05-02-2013, 05:49
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Using the kit rails, you'll need to get 1/4" rivets. The rest of the them could be 3/16" if you drill them for it.
Unread 05-02-2013, 08:46
Andrew Lawrence
Posts: n/a
This looks Rastogi-ish.
Unread 05-02-2013, 08:48
Nathan Streeter's Avatar
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
Definitely! In fact, I would consider using those gusset/bracket/plates instead of the standard blocks for the AM frame almost solely so you could use 1/4" rivets!
Switching to rivets would probably save 2-4 pounds from that frame... in my rough estimation, at least! :-)
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
Unread 05-02-2013, 09:07
This was all Brandon & kids.
Unread 05-02-2013, 11:28
AKA: Brandon Liatys
At the rate were going we actually need to add weight to the bottom of the frame. Plus, we had the bolts already so its cheaper for us as well (tight budgets are fun!). We managed to get this amazing machining sponsor that not only cuts for free but supplies materials, and does so for about 3 or 4 teams in our area. Without them I don't know what we'd be doing this year.
