Go to Post "What connection is the most vital to the success of your robot?" The one between the drivers brain and hands, and the one between the coaches brain and mouth. None of the other ones matter if those two don't work. - dlavery [more]
Unread 05-02-2013, 12:35
RonnieS's Avatar
RonnieS RonnieS is offline
Just a tad washed up
AKA: Ronnie Sherrer
FRC #0314
RonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond repute
Stop After Your Alliance Partners???
I was under the impression that your alliance is only awarded the points for your teams lowest robot climb on the pyramid. For example, if your alliance had one robot at 30pt level climb than another alliance member did a 10pt hang that you only are awarded the points for your 10pt hang. Please clarify.
"Do not argue with an idiot. He will drag you down to his level and beat you with experience"
Unread 05-02-2013, 12:37
Shu Shu is offline
FRC #2137 (TORC)
Shu is an unknown quantity at this point
Re: STOP AFTER YOUR ALLIANCE PARTNERS???
You are awarded points for each robot individually.
Unread 05-02-2013, 12:42
RonnieS's Avatar
AKA: Ronnie Sherrer
FRC #0314
That is how I took the rule but was told today something totally different so I wanted to confirm, also didnt ahve access to the rules currently. Thanks
Unread 05-02-2013, 12:43
False, each robot's hang is scored individually.
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
You may want to revist the game manual:
http://frc-manual.usfirst.org/viewItem/3#5
Unread 05-02-2013, 12:47
RonnieS's Avatar
AKA: Ronnie Sherrer
FRC #0314
I would have but did not have access to the manual so found the best way to find out would be from other FIRST students and mentors. Thanks
Unread 05-02-2013, 12:48
pfreivald's Avatar
AKA: Patrick Freivald
You had access to Chief Delphi, but not the manual? Are they not both online?
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
I had students of both of my teams come up to me and ask me about this. I am very curious to how this rumor started and how multiple teams came up with the same misinterpretation.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Tem1514 Mentor's Avatar
Tem1514 Mentor Tem1514 Mentor is offline
FRC #1514
Tem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to behold
Something else to watch out for is the Q&A 354. I find both the question(s) and answer(s) very interesting.
Unread 05-02-2013, 12:51
RonnieS's Avatar
AKA: Ronnie Sherrer
FRC #0314
The school blocks Game manual but not chief! I thought the same exact thing when i was trying!
Unread 05-02-2013, 12:58
pfreivald's Avatar
How odd!
Team 1551
I write books, too!
Unread 05-02-2013, 13:04
RonnieS's Avatar
AKA: Ronnie Sherrer
FRC #0314
How odd!
Got to love school filters! So Chief was the best choice and I knew that I would get a lot of people to help!
Unread 05-02-2013, 13:32
protoserge's Avatar
You should have your teacher contact the web admin to unblock *.usfirst.org
Unread 05-02-2013, 13:49
Joining the 900 Meme Team
FRC #0079
Re: Stop After Your Alliance Partners???
Let's not talk about breaking school rules shall we?
Unread 05-02-2013, 14:03
kmusa kmusa is offline
AKA: Karlis Musa
FRC #0639 (Code Red Robotics)
kmusa is just really nicekmusa is just really nicekmusa is just really nicekmusa is just really nice
Maybe, maybe not. Rebound Rumble had a similar rule. IIRC, they kept the bridge scoring the same at Championships.
I don't have a problem with the GDC adjusting this aspect of the game, as they watch the evolution of play during regionals.
-Karlis
"A society without contrasting ideas will never move forward; however those contrasting ideas must be based on fact, must be rational/logical, and must be presented in a respectful manner." -Arthur Dutra IV
"If the district can spend $1.5M on turf, it should be able to fund a FRC team." -Sophie Halter
