Go to Post If you can't make them fit on the robot, then those features don't really add much value. - Cory [more]
Unread 05-02-2013, 14:16
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Re: Stop After Your Alliance Partners???
[quote=Undertones;1228097]Or, install ####### to a USB drive and run it from there. Proxies made easy.
Be careful with things like this.
Originally Posted by Chief Delphi Site Rules
ChiefDelphi also reserves the right to prohibit or delete discussions that are thought to violate applicable law, are NOT robotics related, or that may be harmful to other members. Please remember, you are representing not only yourself, but your team and its sponsors, as well as what FIRST stands for. Please try to practice gracious professionalism at all times.
By clicking the Agree button, you warrant that you will not post any messages that are obscene, vulgar, sexually-orientated, racist, hateful, threatening, or otherwise violative of any laws or school rules. THIS INCLUDES THE DISCUSSION OF WAREZ, FILE-SHARING PROGRAMS, CRACKING, AND ANY OTHER WAY OF STEALING SOFTWARE OR ANY OTHER COPYRIGHTED MATERIAL. You also agree not to post the same message in multiple forums, or use the forums as a real-time chat, continuing a 2-3 person conversation on for numerious posts in a short period of time.
Please don't advocate the use of proxies or other illegal methods on Chief Delphi.
Hi!
Unread 05-02-2013, 14:28
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: STOP AFTER YOUR ALLIANCE PARTNERS???
Originally Posted by kmusa View Post
Maybe, maybe not. Rebound Rumble had a similar rule. IIRC, they kept the bridge scoring the same at Championships.
I don't have a problem with the GDC adjusting this aspect of the game, as they watch the evolution of play during regionals.
-Karlis
The GDC also stated they might adjust points by +-10.
If the GDC lowers the point values by 10, hanging on the bottom rung would be useless.
Likewise, if they raise the values by 10, hanging on the bottom rung becomes worth half the value of the top rung, compared to the previous 1/3rd value.
Personally I think that the point values are great the way they are.
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 05-02-2013, 14:59
TheMadCADer TheMadCADer is offline
TheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant future
They could adjust the points for some levels and keep other levels the same. One situation I could see is the second and third level climbs each increasing by 5 points, while a level one climb remains at 10 points.
Tem1514 Mentor's Avatar
Tem1514 Mentor Tem1514 Mentor is offline
FRC #1514
Tem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to behold
Oh no it gets better then that.
According to the wording the GDC may change the point value up or down but not the same for every level. The way it reads they could make level 1 worth 0!, level 2 worth 10 and level 3 worth 40 or some other combination. Who knows how the GDC thinks. Now where is my crystal ball.
