Go to Post A wise man told me a few nights ago, that it is important to own up to all your mistakes, so that others can see you doing that and wont deny and try to hide their own. - Josh Hambright [more]
Unread 05-02-2013, 14:23
MamaSpoldi's Avatar
MamaSpoldi MamaSpoldi is offline
Programming Mentor
AKA: Laura Spoldi
FRC #0230 (Gaelhawks)
MamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant future
Re: Equation for converting potentiometer voltage into angle?
Here is the equation we used last year:
positionDeg = (analogPot->GetAverageVoltage() - INHERENT_ZERO) * VOLTAGE_TO_DEGREES;
where INHERENT_ZERO was a value we measured and defined within our code for the position we chose to view as zero degrees;
and VOLTAGE_TO_DEGREES was a value calculated ahead of time to convert the voltage over a 90 deg travel into degrees. (This is simple to do because it is just a linear conversion. Take the difference of the pot voltage at 0 and at 90 and then divide by 90 to get this value.)
Hope that helps.
