Go to Post So every 3 years robots have to lift robots? There's yet another pattern to consider. :p - ruacubfan2 [more]
Unread 05-02-2013, 14:39
pyroslev's Avatar
pyroslev pyroslev is offline
VirginiaFIRST FTA
AKA: Jack of all trades, Master of few
no team (Forget not 616)
pyroslev is on a distinguished road
Re: [FTC]: Samantha - Connectivity at Comps
Below is a link to the alternate wiring method for the Samantha Module. This way your Sam shouldn't brown out and reboot at the drop of a hat.
The loose wiring aspect is also common. I tell teams to check the wiring after a match when I see a rebooting Sam and they don't check thoroughly. My advice is when you leave the field, start checking wiring connections and anywhere it can come loose, even the battery connections, to make sure your connections are solid.
http://www3.usfirst.org/sites/defaul...tha-wiring.pdf
"Complications arose, ensued...were overcome." "I'd trade 500 CNC machines for one good hearted student."
From December to April, since 2002, I forfeit my mental sanity for perfect insanity.
