Go to Post Haters gonna hate, Cheesers gonna cake. - Ryan Dognaux [more]
Unread 05-02-2013, 14:41
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Re: Team 2992 - 30 pt Climber - Top target dumper
Originally Posted by JB987 View Post
Have you calculated how long it will take to fill your tanks needed air volume between matches (using only one legal compressor) and how long the climb will take? Turnaround can be 10 minutes or less during elims...
Is it illegal to have pre-loaded air tanks and then just swap them out after every match? Then you could be loading them back up during matches and then just get a rotation just like teams already do with batteries.
1592(Student and Mentor) 2007-Present
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
TheMadCADer TheMadCADer is offline
TheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant future
Originally Posted by Chuck Glick View Post
Why dump only 4?
Take 2x 3pt penalties and score the last two colored discs too. Still a net gain of 4 points.
A strategy designed around intentionally taking penalties is a good way to get a red card. It's one thing to occasionally take a protected zone penalty or similar during a match and have it turn out to have a positive effect for your alliance (tubes in lanes in 2011 is a good example), but building a robot around doing so will violate the perennial "spirit of the game" rules.
Still, it's not a good idea to design a game where breaking the rules helps you. GDC should have written the rule so that each extra disc is penalized according to the maximum amount of points it could score. White discs cost 3 points, and coloured discs cost 5.
Unread 05-02-2013, 14:44
sircedric4's Avatar
sircedric4 sircedric4 is offline
AKA: Darren
no team (The SS Prometheus)
sircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond repute
Better than calculated we have run a full up systems test of the pneumatic system because we were very aware of the 5 minutes you have in the later elimination rounds to reset your robot.
We are running at 4 minutes 30 seconds with the legal big compressor. Volume of air, Cg, and weight were some of the big design drivers in order to get the robot we designed to work.
We felt comfortable showing off our design in week 4 because for someone to copy it at this point they would pretty much have to scrap everything they have. The whole robot was designed for this one purpose and just adding a couple of lift cylinders and a lot of air storage to an existing robot won't get you the 30 pts.
We won't truly know how long the climb takes until we can do a full up system test this weekend, but we were shooting for 30 - 45 seconds maximum.
Unread 05-02-2013, 14:46
dodar's Avatar
Is it legal to use your dumper in the bottom goal?
Unread 05-02-2013, 14:55
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Yes, that would be considered illegal. All compressed air must be provided by the one compressor used for the robot (either on-board or off-board, not both), and be charged but the robot battery while under cRio control - essentially, you have to have your robot sitting there in order to charge your tanks.
Further, I would question the safety of moving, handling, and mounting air tanks while they are fully pressurized.
2016: Lake Superior WFFA
Unread 05-02-2013, 14:57
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
I have not seen any rule against 'breaking the plane' of the front of the goal. I was surprised not to see it. Perhaps the GDC remembered the lessons from inadvertent violations in 2006 with the floor goals.
Hi!
Unread 05-02-2013, 15:00
dodar's Avatar
Well if it isnt illegal, then they could, technically, score up to 56 points per match if they have an auto into the bottom goal.
Unread 05-02-2013, 15:02
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
I don't see why having a large number of tanks would be illegal. The conditions your describe aren't mutually exclusive with having many air tanks. A team could simply fill them up on practice day or during breaks. However, an additional condition would have to be added: all tanks used count toward the weight limit, not just the number that would be on the robot at once.
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 05-02-2013, 15:15
familyguyfreak's Avatar
familyguyfreak familyguyfreak is offline
AKA: Xavier Eldridge
FRC #4209 (TigerBytes)
familyguyfreak is an unknown quantity at this point
Send a message via AIM to familyguyfreak
Originally Posted by sircedric4 View Post
We had a strategy meeting at the beginning of our season and discussed the maximum points we could deliver given our limited resources. During that strategy meeting we figured a consistent 50 pt robot would be a good alliance teammate for nearly every game. The rest of the time we will be playing defense.
We have been focusing on reliability and robustness because the climb and dump is such an all or nothing approach.
This year has been very exciting for us. My fellow mentor and I personally like these years where it is extremely difficult to do it all and forces specialization.
For instance during Rack and Roll we concentrated on the ramps for our robot and were very happy with that consistent 60 pts.
It's awesome to see that we aren't the only ones that decided to go with this idea. I love your design over ours though . I'm thinking if we get matched up at Bayou, it's going to be a race to see who can climb and score 50 the fastest!! Or better yet, we might complete one of the first double 30 pt climbs!!! Now I can't wait for Bayou to get here!! See you guys in a little over a month and we look forward to see the final design!!
DiscoBots:
2009: Member
2010-Present: Mentor
TigerBytes:
2012-Present: Mentor
Unread 05-02-2013, 15:21
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Pretty sure it will be too crowded at the top for two inside climbers of the size represented in this thread...
"A genius is just a talented person who does his homework" T. Edison
Unread 05-02-2013, 15:28
Sorry I didn't clarify. Our design is to climb from the outside and dump with an arm. We thought about going under and climbing from the inside but we couldn'd come up with a design to score the frisbees like 2992 has. A dumping arm was really simple for us to go with and it also allows us to score in the low goal as well if needed. We've got pictures of what we've come up with so far on our Facebook page.
https://www.facebook.com/TigerbytesRobotics
DiscoBots:
2009: Member
TigerBytes:
Unread 05-02-2013, 15:30
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
If air volume is an issue, scrap the 2" cylinder in lieu of a smaller bore. Make up for the loss of force via constant-force springs. It'll take some calculations to ensure you're still where you need to be. The tradeoffs would be cost (need to purchase new cylinder(s)) & space (CFS's are 2" wide for that amount of force) versus air consumption. Weight & c.g. will probably be about the same.
I love that CAD animation. It's probably the coolest thing I've seen all season.
It will be interesting to see what happens with all of the center-based 30-point climbers. It's also interesting to see that there haven't been any tangible claims (photos, video, sketches of ideas) of a corner-climber yet.
2017 Scoring Model
CAD Library | GitHub
Unread 05-02-2013, 15:36
Mentor, LRI, MN RPC
The process originally described was to load tanks during the match, which would imply that the robot (including battery and cRio) were not part of the process, thus illegal. I would still be extremely concerned about safety, even if everything was loaded up from the robot. That safety concern (handling and mounting pre-charged storage tanks) could very well be enough to cite R08.
Unread 05-02-2013, 15:43
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
In the past the rules have been such that you must use the battery you plan to use during the match. I haven't seen a Q&A about it this year, so I am not sure if that is still the correct ruling. R80 is unclear.
I can't wait to see this at Bayou.
Unread 05-02-2013, 16:11
Rhelik's Avatar
Rhelik Rhelik is offline
AKA: Bernard Trombley
FRC #0250
Rhelik is on a distinguished road
I am concerned the way your dumper works that you won't actually get the points for all those discs.
See this Q&A.
Q314
Q.If several DISCS are stacked on top of each other in the PYRAMID GOAL, but the top DISC in the stack is completely above the yellow horizontal opening (in the illustration) due to the lower DISCS in the stack holding up the top DISC in the stack, would that top DISC be considered scored?
A.No. Please see Section 3.1.5.1.
You might want to make sure they're stored at a slight angle so when you release them they spread out.
-Bernie
_____________________________
Bernard Trombley
bctrombley@gmail.com
Mentor: Team 250
