Go to Post I suspect the GDC is enjoying watching teams wrap their heads around this ranking algorithm.... and is probably a bit surprised that it has taken teams so long to clue in to the options this ranking system presents to them. - dtengineering [more]
Unread 05-02-2013, 18:48
theface3352's Avatar
theface3352 theface3352 is offline
AKA: Luke
FRC #3352 (Flaming Monkeys)
theface3352 is an unknown quantity at this point
Controlling pneumatic Cylinder on a Joystick?
Hi,
My team wants to use a pneumatic cylinder to control the angle of the shooter and they want to know if it is possible to control it on a joystick so you could for example tell it to go 35% of the way out. Is this possible? Is it a good idea?
Any help is appreciated!
Unread 05-02-2013, 21:05
Re: Controlling pneumatic Cylinder on a Joystick?
It's technically possible to give air slowly to a pneumatic cylinder and stop when it's where you want it to be.
It's not a good idea, especially for something that will be bearing much of a load. It'll be springy/bouncy at best. Pneumatic cylinders aren't great at holding a set position that isn't at one end or the other of their travel.
