Go to Post however, if i tried it i would probably end up setting my hair on fire - Henry_Mareck [more]
Unread 21-01-2003, 22:19
Gobiner Gobiner is offline
#0753 (High Desert Droids)
Gobiner is an unknown quantity at this point
Send a message via ICQ to Gobiner Send a message via AIM to Gobiner
Selecting Autonomous Behavior
Haven't seen a thread on this, and there should be one. People are planning on having multiple behaviors that they can choose from for the autonomous mode. Is everyone planning on having 2-4 different programs on their laptops and simply uploading whatever program they feel like before the match? Is anyone having 2-4 all in a single program and using something on the robot to select which code to use during autonomous play? The first would be easier but the second would prove you are programming/electronics ninjas.
Unread 21-01-2003, 22:27
n[ate]vw's Avatar
n[ate]vw n[ate]vw is offline
#0933 (Adler Attack)
n[ate]vw is an unknown quantity at this point
Send a message via AIM to n[ate]vw
We are programming/electronics ninjas, no?
It would not be that difficult to throw a rotary selector switch on whatever digital inputs are empty on the RC. Then, right before you moved the robot onto the field, you could turn the switch to select the proper subroutine. There have been threads on this rather recently, I think.
Adler Attack #933 -- Trigos
PyroPhin's Avatar
PyroPhin PyroPhin is offline
None #0263
PyroPhin is on a distinguished road
would be much easier to have a swich that you could hit to change wich program you want to execute.. and, you dont even have to be a ninja to do it!
just do an if then loop:
if rc_sw1 = 1 then prog1
goto endauto
prog1:
blablabla
:endauto
plus, a row of teeny silver toggles makes any robot look sexier
~Pyro
Squee!
Team 263, Aftershock:
Alumni, guy who comes back and fixes Krass's mistakes
Unread 21-01-2003, 22:29
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
And if you're a true "l337 hax0r", you could even wire them to the four-consecutive, nibble-aligned switches, and do a SELECT on the nibble. Mmm... nibbles....
Unread 21-01-2003, 22:33
Crap, forgot about robot sex appeal. Now I'm going to have to redesign the entire electrical system to use shinier things. But I want to know what you guys are using, or even if you're using multiple behaviors.
0N3 1337 PR0G|24MM1N6 N1NJ4
Unread 22-01-2003, 09:44
Ryan Meador Ryan Meador is offline
Team Role: Electrical
Ryan Meador will become famous soon enough
And don't forget the RUN command! That's how we're doing it. I've got it all set up to configure everything, jump into user-controlled mode, flip to a user-selected autonomous program when it receives the auton_mode signal, and then pop back to human control. I might change it to go straight to the auton program to save the 26 milliseconds it takes to do the switch
-Ryan
"You're not a real programmer until you end all your sentences with semicolons;"
A better autonomous method.. randomperson Programming 4 24-02-2004 18:02
crazy idea for autonomous Mike Ciance Programming 16 24-04-2003 21:50
variable? manodrum Programming 11 01-04-2003 17:20
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Autonomous Kill Switch UCGL_Guy Programming 8 15-01-2003 17:39
