Go to Post Look for metal shavings in a pwm port; that's caused us to crash plenty of times. - Gary Dillard [more]
Unread 05-02-2013, 20:39
litterClean litterClean is offline
FRC #3734
litterClean is an unknown quantity at this point
Bumper height
Our team has run into a problem with the bumper height using the frame that comes with the kit. Using six inch wheels, the frame is only 2.25 in off the ground. this leaves very little room to for us to mount the bumpers on the frame. Is there a common work around for this?
Unread 05-02-2013, 20:41
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
Re: Bumper height
If you mount the bracket on the center of the bumper, doesn't that leave a pretty snug fit?
I can understand if you want to have some ground clearance though - in that case, why don't you just mount the bumper-frame brackets slightly below center? (thus displacing the bumper higher from the ground)
FTC Teams 5257, 6568 & FRC Team 3992
2014 FTC WORLD CHAMPIONS
14 Trophies in 3 Years
Unread 05-02-2013, 20:54
FRC #3734
Re: Bumper height
The concern is that according to the rules, the bumpers appear to need to be at least 2" off the ground (http://frc-manual.usfirst.org/viewItem/181#4.1) (r25). That said, our robot is only about 2.75" off the ground as the wheels are 6" in diameter, which puts the fasteners at the bottom most edge of the wood. Is that rule hard set or can we put it just 1" or .5" off the ground? Obviously ground clearance is ideal, but we want to make sure the bumpers dont break off.
Unread 05-02-2013, 20:58
ksafin's Avatar
AKA: Kirill Safin
Re: Bumper height
Ah, sorry, I missed that (we didn't start our bumpers yet).
I don't see the rule changing, so you should start accommodating it.
The best I can think of is to make some kind of metal C-Channel or bar slightly elevated from your C-Channel perimeter that you can mount to the center of the bumper to meet the ground clearance rule.
Unread 05-02-2013, 22:48
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Bumper height
If your bumpers are 1 inch or half-inch above the ground you will fail inspection.
Unread 05-02-2013, 23:21
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: Bumper height
Put your attachement near the bottom of the bumper so you can satisfy the 2" requirement. Have some vertical supports behind the bumpers that keep it from rotating. These would be permanently mounted to your frame, so you could make them very stable.
Attaching and supporting bumpers can really be thought of as two separate things!
2016: Lake Superior WFFA
Unread 06-02-2013, 12:21
DELurker DELurker is offline
Former Engineering Mentor
AKA: William Lydick
no team (n/a)
DELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant future
Re: Bumper height
After re-reading the OP's two posts, I'm confused as to what the question is...
The bumper rule is unchanged from last year regarding the heights. The short form is that the bumpers must be 5" tall and have a minimum ground clearance to the bumpers of 2" and a maximum of 5". Since the OP apparently has some part of their frame (a pic or drawing would help) 2.75" off the ground, there is a mounting location for the bumpers within the permitted zone.
Of course, this may alter how the OP wants to attach the bumpers, but everything is about adaptation to opportunities, not dealing with problems
With 1370 --
2012 Rutgers District Event Champions with 1676/56
2012 Lenape District Event Finalists with 2191/1691
2013 TCNJ District Event QuarterFinalists with 1143/4750, Gracious Professionalism Award
2013 Bridgewater-Raritan District Event Semi-Finalists with 4285/223
2013 MAR Championship Finalists (Backup) with 222/11/1403; Gracious Professionalism Award
