Go to Post FRC did a lot for me in high school. I couldn't pass up the opportunity to help it do the same for others. - Oblarg [more]
Unread 05-02-2013, 22:34
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
Re: 50 POINTS
Originally Posted by Nicolas BR View Post
Do 50 points in every game in the qualifiers is a good score?
Won't be able to give a definitive answer until week one. Right now, I would say it's a close call. I would also have to know how you're scoring the 50 points.
If you're scoring it as most people assume, with a 30 point climb and 20 point dump, then I would say that it may not be enough. While most likely a consistent method of scoring, potentially has the issue of being capped at 50 points. Possibly more if you can dump in autonomous and during the match, but you'd be hard pressed to break 65-70 points per robot.
If you're scoring the 50 points by shooting and a 10 point hang, it may be better than a 50 point climb/dump. Reasoning: The 18 points in autonomous should be a given. As well, a 10 point hang should also be a given, especially with designs like Spectrum 3847's simple passive hanger. That leaves 22 points to be scored by a shooter. Which is three full hoppers of frisbees to the top goal. Entirely do able in a minute and thirty seconds. Why this is better: This robot would be easily improvable to surpass 50 points by either making more trips to the feeding station (Driving practice = ability to dodge defenders or ability to change drive ratio for faster drive train.) OR the ability to add a floor pick up system and VASTLY cut down on trip time whitch would easily make 4 or 5 full hoppers feasible.
TL;DR a 50 point shooter could be improved upon. A 50 point climber is essentially capped at 50 points. You won't know until competition whether 50 points is a lot or a little. You may get there and teams "bluffed" their accuracy in their videos. You may get there and find out that all the shooters are bats out of hell and dang accurate.
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
