Go to Post Don't like it? Then lets change the culture. - Barry Bonzack [more]
Unread 02-02-2013, 20:11
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
2073 800+ Lb winch
With this we will be able to move from one level to the next in a 3.2 second pull. It is capable of lifting an entire alliance with one CIM!
http://www.youtube.com/watch?v=QvJWH_ZjcSU
Unread 02-02-2013, 20:14
CalTran's Avatar
CalTran CalTran is offline
MST Rolla Senior
Re: 2073 800+ Lb winch
The 814 number, is it calculated or tested?
Academic Student (Forever)
Unread 02-02-2013, 20:48
billbo911's Avatar
Calculated with the JVN Mechanical Design Calculator.
Unread 05-02-2013, 16:20
JimC JimC is offline
FRC #1073 (The Force Team)
JimC is an unknown quantity at this point
If that is #35 chain that you are using (I can't quite tell) then be careful because it only has a load rating of 480lbs.
Of course you're not really going to lift 800 lbs, I'm just pointing out that the load calculator doesn't take everything into consideration.
Be careful, have fun!
Jim
Unread 05-02-2013, 16:28
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
I have a very strong feeling that your chain is gonna catch whatever you are using as your "cord" for the winch and it will either snap or cook the motor.
1592(Student and Mentor) 2007-2012
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 05-02-2013, 16:54
billbo911's Avatar
Jim
Understood! We have no intent of carrying others up the Pyramid. Our 150Lb. is all it will ever see.
Guard(s) and guides will be in place to prevent this issue. Alternatively, we might swap out the 36 tooth sprocket for a 22 tooth. This will bring the chain inside the OD of the spool. It will also increase our climb rate by 1/3 without over stressing the CIM.
With the current design, the calculated current draw is 39.75A for a 150 Lb. load. With the 22 tooth sprocket, that value goes to 63.33A. Additionally, it would reduce the lift time for a 30 in. pull to 2.32 sec. Not enough to trip the breaker. It would also reduce the controllability for the drivers. So, we will start out with the 36 tooth and see if there is even a need to go to 22.
BTW, from Wikipedia:
ANSI B29.1 roller chain standard sizes
Size Pitch Roller diameter Tensile strength Working load
25 0.250 in (6.35 mm) 0.130 in (3.30 mm) 781 lb (354 kg) 140 lb (64 kg)
35 0.375 in (9.53 mm) 0.200 in (5.08 mm) 1,758 lb (797 kg) 480 lb (220 kg)
Unread 05-02-2013, 18:04
EricPalmatier's Avatar
EricPalmatier EricPalmatier is offline
FRC #0250 (The Dynamos!)
EricPalmatier is a splendid one to beholdEricPalmatier is a splendid one to beholdEricPalmatier is a splendid one to beholdEricPalmatier is a splendid one to beholdEricPalmatier is a splendid one to beholdEricPalmatier is a splendid one to behold
Send a message via AIM to EricPalmatier
First, congrats on the awesome winch! Looks similar to something I have been working on! Just two quick questions. The first is what is you final calculated gear ratio before the winch drum? And second, you stayed that the close to 60 amps would not trip the breaker? I would think that's true of the main 120 amp breaker, but what about the 40 amp breaker feeding your motor controller from the PDB?? Just curious, and good luck!
"Engineering is a great profession. There is the satisfaction of watching a figment of the imagination emerge through the aid of science to a plan on paper. Then it moves to realization in stone or metal or energy. Then it brings homes to men or women. Then it elevates the standard of living and adds to the comforts of life. This is the engineer's high privilege."
-Herbert Hoover
Unread 06-02-2013, 00:33
billbo911's Avatar
Here are the reduction stages we are using:
Toughbox Mini: 50:14 and 48:16
Next stage spur gears: 48:17
Final stage chain: 36:12
Total reduction is 90.67:1
The 40A snap action breakers can handle a heavier load for a short period of time. 60A for 5 seconds is fairly safe.
