Go to Post Enlighten a man who sometimes has difficulty understanding why others stray outside the box, when the box appears to be an optimized and elegant solution. - JVN [more]
Unread 06-02-2013, 08:11
Re: Moving a motor a certain degrees?
You don't need to use an encoder, but you do require some kind of feedback sensor to tell you when the motor has moved the desired amount. For a one-rotation action, a lever arm or cam and limit switch might work.
