Go to Post Are they Robots? Of course they aren't robots; they are obviously and unambiguously robots. - gblake [more]
Unread 06-02-2013, 01:20
Turtleinator's Avatar
Turtleinator Turtleinator is offline
FRC #1816
Turtleinator is an unknown quantity at this point
Robot Signage
My team has been debating how to display our sponsors and team branding on our robot this year. Traditionally we have used printed vinyl banners that were attached with Velcro (that never stayed on long enough) and eventually zip-ties. We found that it was annoying that the banners would tend to fold, and that they had a tendency to fall off or to be a complete hassle to remove (and nowhere in-between ).
This year we were thinking of using 1/8" green polycarbonate with stickers for the images we wanted. This would make the robot signage far sleeker and more stable yet also easier to remove. The problem with this however, is that we are very worried that the panels will get broken (they are on the edge of our frame perimeter due to the density of our robot). Can any teams with experience with polycarbonate signage offer some help? Thank you!
Also, if anyone has a suggestion for a good custom sticker company ,that would be helpful. As we are having trouble finding local companies that can do that.
Unread 06-02-2013, 01:32
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Re: Robot Signage
Our team has generally used 1/16" clear Lexan for not only a "shell", but also to put our branding and logos. It is usually stuck on with small squares of Velcro. This makes them easy to remove, but won't fall off during a match (at least not yet).
As for the stickers, we have just printed our logos onto heavy cardstock and attached them with clear packing tape from the inside. It's very hard to see the tape from the stands, especially when there is a match going on to distract them!
I'm right 90% of the time, so why worry about the other 3%?
Unread 06-02-2013, 01:34
Nirvash's Avatar
Nirvash Nirvash is offline
AKA: Bryan
FRC #4676
Nirvash has a spectacular aura aboutNirvash has a spectacular aura about
Re: Robot Signage
I've always used inkjet printable stickers and printed them myself, they come as full sheets which we then cut down to size.
Also, I wouldn't worry too much about breaking a polycarbonate panel, it is very strong.
Team 3488 - Electrical Lead/Programming Lead 2011-2013
Team 4676 - Electrical/Programming Mentor 2013-Present
Unread 06-02-2013, 01:53
Botwoon's Avatar
Botwoon Botwoon is offline
A.K.A. Matthew Ruane
FRC #0207 (Metalcrafters)
Botwoon will become famous soon enough
Re: Robot Signage
http://i.imgur.com/v27IukR.jpg
Last year we cut letters/patterns on our laser inverted and stuck them to the inside of our panels, then backed the panels with a thin coat of silver lexan paint. Under the right light, I think the panels look to be made of sheet metal.
Unread 06-02-2013, 07:25
Billfred's Avatar
Billfred Billfred is offline
Re: Robot Signage
We've done it a few ways over the years. Some years, we had stickers printed up. Some years, it was cut vinyl lettering adhered to the arm. Way back when, we'd also print large pieces on a plotter, laminate them, and velcro them into place--if you're inside the frame perimeter, this one can be cheap and light.
Unread 06-02-2013, 08:52
James1902's Avatar
James1902 James1902 is offline
Chopsaw??
FRC #1902 (Exploding Bacon)
Team Role: Marketing
James1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond repute
Re: Robot Signage
We've gone with Lexan (2007) (2009)
We've gone with printed cloth (2010)
And we've gone with laminated paper (2011)
We prefer the laminated paper just because it's easy and light, but I can understand your frustration with it.
We've never had a problem with our Lexan breaking when we used it and we kind of abused all of the robots that had it. Also we just printed the logos out on a decent quality printer and taped them to the Lexan, the quality is fine and you wouldn't have to find a sticker supplier.
-In case of major discrepancies it's reality that's got it wrong
-oink oink boooooooooooooooooooooooooom
-Iz it can b pig go boom time now plz?...kthanxbye!!
Unread 06-02-2013, 08:58
Brandon Zalinsky's Avatar
Brandon Zalinsky Brandon Zalinsky is offline
Roaming GeorgiaFIRST MC
AKA: The Mecanum Man
FRC #1058 (PVC Pirates)
Brandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant future
Re: Robot Signage
We usually use 1/4" black corrugated plastic.
2012- Front (Team name and logo) (We're on the left)
http://www.flickr.com/photos/kimsrobot/7457907638/
Back- Sponsors:
http://www.flickr.com/photos/kimsrob...n/photostream/
This is our Robot. There are many like it, but this one is ours.
Measure twice, cut once, curse, buy more, and cut again.
2014- Excellence in Engineering (UNH), District Chairman's Award (NU), #8 Quarterfinalist (NECMP), Winner (Mainely Spirit)
2013- Semifinalists (Battlecry@WPI) Winner (Mainely Spirit)
2012- Regional Chairman's (GSR), Finalists as the #11 Alliance Captain (Battlecry@WPI)
2011-Xerox Creativity Award (GSR), Semifinalists (GSR) Innovation in Control (Virginia)
2010-Champion (GSR), Undefeated (Chesapeake), Coopertition Award (Chesapeake), Quarterfinalists (Galileo) 8th AC (IRI)
2008-Undefeated (GSR), Xerox Creativity Award (GSR)
Unread 06-02-2013, 09:08
Re: Robot Signage
We have used Lexan with velcro for years.
Unread 06-02-2013, 09:14
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
Re: Robot Signage
Our usual method is stickers of some sort on 1/32nd Lexan panels that are mounted with Velcro.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 06-02-2013, 10:17
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Re: Robot Signage
You could try fastsigns in Bloomington - 2470 has been using them since 2008 and they remember us every year!
http://www.fastsigns.com/190-bloomington-mn
As for the polycarbonate breaking, we have only had that happen once. Last year we were lifting the robot into a car for an outreach event and the polycarbonate got sandwiched between the floor and the robot. Snapped right in half! Otherwise it hasn't been a problem.
We usually throw some industrial strength velcro on the back of the polycarbonate and velcro it to our robot. As long as you do not get any metal or wood shavings in the velcro fabric it should hold through all of your matches.
Feel free to pm me and I can try to find our contact for the Bloomington Fastsigns branch.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 06-02-2013, 10:38
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Robot Signage
If you break 1/8" polycarbonate then you have much bigger problems and probably a severely broken robot.
You could use much thinner, like others have said, and save a lot of money and weight.
We have used Velcro and much thinner polycarb film and have never had a problem.
Unread 06-02-2013, 12:26
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: Robot Signage
The same people that print on vinyl can probably also print on yard sign material--a honeycomb plastic light & reasonably stiff. Looks better than stickers for the most part.
Unread 06-02-2013, 16:29
wonder-weasel's Avatar
wonder-weasel wonder-weasel is offline
AKA: Christa
FRC #0930 (B.E.A.Rs)
wonder-weasel is an unknown quantity at this point
Re: Robot Signage
We've done this just about every year I've been on my team. It works really well, and there should be no worries about breaking. We've always just bought sticker material ourselves, gotten high-res images from our sponsors and printed them ourselves. Works pretty well!
Unread 06-02-2013, 23:39
FRC #1816
Re: Robot Signage
Thanks for all of the help guys! We will probably use polycarbonate this year, and if we can find 1/16" green polycarbonate we will certainly use it.
Unread 07-02-2013, 07:54
drwisley's Avatar
drwisley drwisley is offline
FRC Coach
AKA: Dave
FRC #1756 (Argos)
drwisley has a brilliant futuredrwisley has a brilliant futuredrwisley has a brilliant futuredrwisley has a brilliant futuredrwisley has a brilliant futuredrwisley has a brilliant futuredrwisley has a brilliant futuredrwisley has a brilliant futuredrwisley has a brilliant futuredrwisley has a brilliant futuredrwisley has a brilliant future
Re: Robot Signage
Spray the inside of the the polycarbonate with your green paint. It looks really nice and keeps the sheen on the visible surface.
