Go to Post Whatever you do, do it in graciously professional manner. - EricH [more]
Unread 05-02-2013, 14:41
ohhs4284 ohhs4284 is offline
FRC #4284
ohhs4284 is an unknown quantity at this point
Alternatives to Andymarks 8mm key hub
With Andymark's 8mm key hub sold out, what are our alternatives? We're looking to mount a wheel to a CIM, but our options as far as gearboxes are concerned are limited because the piece we had fabricated to hold the motor doesn't provide room since we didn't expect to need a gearbox. So, what other systems could we use to mount without taking up too much room, or where else could we find an 8mm key hub besides Andymark? We would be willing to buy one off of another team if possible. Thanks.
Unread 05-02-2013, 14:54
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Re: Alternatives to Andymarks 8mm key hub
you could buy a bigger one and turn an adapter. If you have a lathe this should not be to difficult.
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 05-02-2013, 14:55
This sounds like the perfect time to find a machine shop sponsor.
Alternately, you can buy one of AndyMark's 8mm shaft adapter like http://www.andymark.com/product-p/am-0588.htm or http://www.andymark.com/product-p/am-0472.htm and a different hub.
Unread 05-02-2013, 14:56
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
http://www.andymark.com/product-p/am-0588.htm + http://www.andymark.com/product-p/am-0096.htm =
works in a pinch.
--Madison--
...down at the Ozdust!
Unread 05-02-2013, 15:28
Feroz1325's Avatar
Feroz1325 Feroz1325 is offline
FRC #1325 (Inverse Paradox)
Feroz1325 is on a distinguished road
You could try and purchase a flexhub flange (http://www.andymark.com/product-p/am-2445.htm) and a 8mm hub (http://www.andymark.com/product-p/am-flexhub.htm) the hub fits in the flange and the flange has the appropriate hole pattern for IFI and Andymark wheels.
Another option would be to modify an IFI planetary gearbox to accept the cim . Good luck from team 1325!
Feroz Balsara
Team 1325 Inverse Paradox
FIRST Volunteer, College Mentor, Lead Design and Strategy Mentor!
2013 GTR West Semi-Finalists with 1241 and 2013!
2013 GTR East Champions with 1114 and 2056!
2011 GTR West Finalists with 610 and 1334!
Team1325.com
Unread 05-02-2013, 20:09
DonRotolo's Avatar
Back to humble
FRC #0832
Or make a shaft adapter. Made with a drill and a hacksaw. Or buy an 8mm one and drill out the other end for what you need.
Unread 06-02-2013, 10:10
Hebrew Hebrew is offline
FRC #4228 (iRobotics)
Hebrew is an unknown quantity at this point
Originally Posted by Madison View Post
How does the hex hub hold the hex adapter shaft into place?
We are looking for something similar since the normal hubs are sold out.
Unread 06-02-2013, 10:57
Bruceb's Avatar
You put the hex adapter inside the hub and put the 2 in a drill press. Drill a hole with a number 7 drill through both of them to the center hole then run a 1/4-20 tap through the 2 of them. You can then run a set screw through the 2 of them all the way to the CIM shaft.
Hope that helps.
Unread 06-02-2013, 11:35
GDG 2337 GDG 2337 is offline
FRC #2337 (ENGINerds)
GDG 2337 has a spectacular aura aboutGDG 2337 has a spectacular aura about
Commonly used AM hubs routinely go out of stock at inappropriate times during the build season. We noticed 250 hubs never go out of stock. So we decided to buy the necessary drill bits, reamers, key way and hex broaches to make whatever size hub required for the application out of them. We offer this service to the FRC and OCCRA teams in our local area. Check with established teams in your area to see if they could make a 8mm hub from a 250 hub for you.
Unread 07-02-2013, 08:02
Ken Streeter's Avatar
Ken Streeter Ken Streeter is offline
Let the MAYHEM begin!
FRC #1519 (Mechanical Mayhem)
Ken Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond repute
Machined hubs at AndyMark don't usually stay out of stock very long. Our experience is that hubs usually come back in stock again within about 72 hours. The 8mm key hubs (http://www.andymark.com/product-p/am-0320.htm) were back in stock as of yesterday afternoon. We ordered some last night. The hubs are still in stock now.
Ken Streeter - Team 1519 - Mechanical Mayhem (Milford Area Youth Homeschoolers Enriching Minds)
2015 NE District Winners with 195 & 2067, 125 & 1786, 230 & 4908, and 95 & 1307
2013 World Finalists & Archimedes Division Winners with 33 & 469
2013 & 2012 North Carolina Regional Winners with teams 435 & 4828 and 1311 & 2642
2011, 2010, 2006 Granite State Regional Winners with teams 175 & 176, 1073 & 1058, and 1276 & 133
Team 1519 Video Gallery - including Chairman's Video, and the infamous "Speed Racer!"
