Go to Post The Tesla came in the blue tote. This is why you should always inventory your KOP before the replacement window closes! :p - sparrowkc [more]
Unread 06-02-2013, 11:14
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Question Recommendation for Analog Pressure Sensor
Dear CD,
Can anyone recommend an inexpensive, pneumatic pressure sensor that they have used with the cRIO system? Years ago FIRST used a TI sensor but I cannot find that part number online.
Thanks in advance,
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 06-02-2013, 11:24
Re: Recommendation for Analog Pressure Sensor
I don't know how inexpensive ($87) this is, but here's what we used last year.
Search Digikey for : 734-1003-ND
Rated for 200psi (125psi required)
Analog output (0.5 V ~ 4.5 V)
Unread 06-02-2013, 11:26
feverittm's Avatar
feverittm feverittm is offline
FRC #0997 (Spartans)
feverittm will become famous soon enoughfeverittm will become famous soon enough
Please see my earlier posting regarding the legality of using a pressure transducer on the high pressure side of the pneumatics system. I asked and received a Q&A that this is illegal.
If you are using it on the low pressure side (like to modify the output pressure for a shooter), then it should be fine.
Enjoy!
Floyd Moore
Mentor Electrical and Pneumatics
Team 997 - Spartan Robotics
Corvallis High School, Corvallis Oregon
Unread 06-02-2013, 11:45
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
Keep in mind I haven't tested this, but here's a $10 sensor from digikey:
http://www.digikey.com/scripts/DkSea...=8&y=6&cur=USD
I imagine you could simply attach a hose onto the barb and secure it in place, but I'm not acquainted with the tubing ID.
Unread 06-02-2013, 11:54
That's only rated for 72.5 psi
R76
All pneumatic components must be COTS pneumatic devices rated by their manufacturers for working pressure of at least 125psi (with the exception of R78-D).
Unread 06-02-2013, 12:00
Unregistered User
AKA: Kevin Forbes
Right, this would be for measuring pressure downstream of the 60psi regulator. There's a 150psi equivalent (MPX5999D), but I don't believe it comes with the useful plastic molding.
EDIT: didn't see that rule, thanks for pointing it out! The search continues...
Unread 06-02-2013, 12:01
Doesn't matter where you put it. It's not legal unless it's rated for 125psi.
Unread 06-02-2013, 13:20
Unregistered User
AKA: Kevin Forbes
In that case, here's a similar one by Honeywell: http://www.digikey.com/product-detai...552-ND/3475911
Unread 07-02-2013, 17:13
marccenter's Avatar
Thanks everyone,
I just purchased the Honeywell analog pressure sensor (NBPDANN150PAUNV- PN 480-5552-ND) from Digikey for $12.32/pc (2 units). After I hook them up I will let everyone know how they worked out (planning on displaying pressure on the dashboard).
Marc Center
