Go to Post Having the ability, opportunity, and inclination to do manual labor makes you a better engineer. - MrForbes [more]
Unread 06-02-2013, 11:33
Djur's Avatar
Djur Djur is offline
WPILib
AKA: Sam Carlberg
Djur will become famous soon enough
Re: Team 3675's 3 level climber!
Originally Posted by skupitup View Post
Just looking at your design, i'm a little bit worried about the 54 inch diameter cylinder boundary that no robot appendage can violate. I know the the GDC changed the rules about this twice now and im not sure if you have been informed. The general rule is that the 54 inch cylinder includes the bumpers, and that the cylinder is only vertical relative to the field while not in contact with the pyramid. While in contact however, the cylinder is relative to the robot, with that being said, if you must violate the cylinder rule to climb while the robot is sitting flat, with the cylinder relative to the ground, then you also must violate the rule in order to be climb the pyramid. Just wanted to make sure that you were informed about this.
When the robot is in contect with the pyramid, it has to fit within a 54" x 84" cylinder in any orientation. The cylinder is not robot oriented. If the robot isn't in contact with the pyramid, then the cylinder is vertical.
WPILib dev (RobotBuilder, SmartDashboard, GRIP)
