Go to Post If you are content with where you are, you have celebrated the right things. If not, perhaps it is time to reconsider... what’s most important to you. - StephLee [more]
Unread 02-06-2013, 12:15 AM
JewishDan18's Avatar
JewishDan18 JewishDan18 is offline
FRC #1700
JewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to behold
Issue with Talons
Hi all, I was hoping to get some help with a strange problem with some Talons.
Tonight we decided to do driver tryouts with a simple robot consisting of a drive train with two CIMs to each side, all controlled over Talons. Normally it drives fine, but occasionally while driving straight the side going forward (the lights on the Talons are green) reverses for a very quick moment, going backwards. The lights on the Talons turn red when this happens. We are using simple Arcade Drive code, and I've checked the values being sent to the Talons in the code, and they are not reversing at all there. This happens when driving straight forward and backwards at full power (so all 4 Talons have had the issue), but not when purely turning.
We think there is an issue somewhere between (and not including) the crio and the Talons themselves, since it happens to all 4. Additionally, once when powering the robot on one side of the robot moved at a high speed for a very short amount of time, which leads us to rule out code issues.
Tomorrow we plan on replacing the Digital Module, the Digital Side Car, and the cable connecting the two one at a time to see if any of them are causing the issue. Is there anything else we should be doing or checking for that anyone can think of? I tried to give all relevant info but if anything else is needed I can provide it. Thanks!
EDIT: Also, going to try swapping victors for the Talons.
Unread 02-06-2013, 12:23 AM
agartner01 agartner01 is offline
Captain + Control Sys & Design
FRC #4174
agartner01 is an unknown quantity at this point
Re: Issue with Talons
I'd like to add that my team has experienced the same problems... No idea how to fix them.
Unread 02-06-2013, 12:33 AM
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
Here's what we have already tried and some additional info:
We tried turning the robot off and back on. Sometimes this fixed it, other times it didn't, and the problem would intermittently come back after varying amounts of time.
All 3 lights on the digital side car are on.
The observed effect is that the robot is commanded to move forward (and only forward) and it starts out doing so, then pulses a turn to the left, then continues on its way forward.
This happens only when the talon is commanded to go in the green direction. It does not occur in the red direction (or we have yet to observe it).
All 4 of the talons are in coast mode.
[2016-present] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 02-06-2013, 07:53 AM
A brief twitch in reverse can be a sign that the robot is getting disabled for a moment. If the PWM signal is interrupted for just the right amount of time, it is possible for the speed controller to misinterpret the interruption as a valid command. Look at the Diagnostics tab of the Driver Station and see if there are any helpful error messages.
Unread 02-06-2013, 07:56 AM
Have you tried calibrating the Talons?
Unread 02-06-2013, 08:39 AM
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Make sure you do these one at a time. This way if the issue gets resolved after swapping one thing, you can trace the problem to a specific item.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 02-06-2013, 09:11 AM
I would interpret the LED change as a sign that the PWM signal did in fact change state. However, I would like to see Mike C weigh in on this.
Unread 02-06-2013, 10:52 AM
AKA: Carl Springli
Yeah, we have calibrated them.
Unread 02-06-2013, 11:00 AM
AKA: Carl Springli
After printing out the voltage values being sent to the talons to the console, we found nothing that suggests the PWM is changing direction. This leads us to believe it is something other than the code and likely down stream from the cRio causing the PWM signal to flip the other way for an instant.
Unread 02-06-2013, 12:26 PM
BitTwiddler's Avatar
BitTwiddler BitTwiddler is offline
electronics/programming mentor
AKA: Mr Tanguay
FRC #1726 (N.E.R.D.S.)
BitTwiddler is on a distinguished road
Last year we had something similar happen to us.
Observing the PWM output from the Digital Sidecar with an oscilloscope revealed that the PWM signal was dropping out occasionally. Replacing the DSC fixed the problem.
My $.02.
Unread 02-06-2013, 12:33 PM
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
My $.02.
Our digital sidecar this year had a problem with DIO Channel 7 not working, I wonder if there was a problem with the production of the sidecars this year that is causing some of these problems.
Unread 02-06-2013, 01:12 PM
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
We have had a host of problems with the DSC, and had to replace three of them last season. I would definitely look at testing with a new DSC.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 02-06-2013, 01:34 PM
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Also take a look at the ribbon cable from the cRIO to the DSC, especially if you are using one that required repair from last year. Dodgy connections on the ribbon cable can cause strange behaviors.
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 02-06-2013, 01:35 PM
AKA: Mr Tanguay
I don't have any issues with either the design or reliability of the DSC. It's just that it's such a swarf magnet. You really have to be careful working around them.
Unread 02-06-2013, 01:41 PM
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
We too seem to be having an issue like this.
The problem is noted as a drive train twitch. We're using the default drive code (tank) without any modifications.
The issue is experienced with the Talons; however, we're only using the PWM interface with the Talons. All other motor drivers are connected using the CAN bus.
No one is near the controls when this occurs. It is just a brief twitch. I'm a bit worried reading this because we haven't had a good chance to run the robot much yet.
I looked at the schematic for the Digital Sidecar, and I'm not seeing how it can be an intermittent problem with the DSC.
Link for the schematic can be found here.
The PWM signals originate directly from the NI 9403, so the DS isn't actually supplying the PWM signals. There are three 'chips' that touch the PWM signal.
  1. A 10K pullup resistor used for a disconnected DSC. Resistors don't intermittently fail. However, a cold solder joint might cause an intermittent connection; however, this would only affect the system IF AND ONLY IF the 32-pin cable becomes disconnected.
  2. A disable chip. There is a chip, in line, with the PWM signals. This relies on a signal defined as OUTPUT_EN. If this signal toggles while sending a NEUTRAL PWM signal to the speed controllers, this could cause the speed controllers to 'twitch.' However, the OUTPUT_EN line should remain HIGH while the robot is ENABLED.
  3. A current limiting resistor. It's placed between the disable chip and the actual output. Again, resistors don't intermittently fail, and the only issue I can imagine is a bad soldering job.
Just going on a wild hunch... How many of you experiencing this issue are using the home-made DSC cable that connects your DSC to the NI 9403? It's possible that there is an intermittent or high resistance (bad connection) pin that is causing this issue. Looking at the pinout, OUTPUT_EN is DIO_21 on the NI 9403. First, try a different (real) cable. I don't see much failing in the DSC, so I'm pointing my finger at the cables right now.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
