Go to Post a determined team can accomplish miracles. - Wayne C. [more]
Unread 06-02-2013, 12:51
Mr.Roboto3335's Avatar
Mr.Roboto3335 Mr.Roboto3335 is offline
Wait, What?
AKA: Jimmy
FRC #3335 (Cy-Borgs)
Mr.Roboto3335 is an unknown quantity at this point
Drive Issue
Our motors are backwards and my team does not want to reverse the wiring. How do I reverse the motors with Java?
Wait, what?
Unread 06-02-2013, 12:57
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is online now
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Drive Issue
An easy way to do it is just put in the opposite power level. So if you want 0.5 power put in -0.5 instead.
public void drive(double leftPower, double rightPower) {
robotDrive.tankDrive(-leftPower, -rightPower);
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
inkspell4 will become famous soon enough
You make one of the joystick values negative.
For further help we would need your code
Chesapeake Regional : 2013, 2012, 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
Unread 06-02-2013, 12:59
Re: Drive Issue
*-1
or I think this is still valid from last year?
drive.setInvertedMotor(RobotDrive.kFrontLeft, true);
drive.setInvertedMotor(RobotDrive.kRearLeft, true);
Unread 06-02-2013, 13:00
Wait, What?
AKA: Jimmy
Re: Drive Issue
This is it so far.
/* Copyright (c) FIRST 2008. All Rights Reserved. */
/* Open Source Software - may be modified and shared by FRC teams. The code */
/* must be accompanied by the FIRST BSD license file in the root directory of */
/* the project. */
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.SimpleRobot;
import edu.wpi.first.wpilibj.Timer;
* The VM is configured to automatically run this class, and to call the
* functions corresponding to each mode, as described in the SimpleRobot
* documentation. If you change the name of this class or the package after
* creating this project, you must also update the manifest file in the resource
* directory.
public class TheReaper extends SimpleRobot {
RobotDrive drive = new RobotDrive(1, 2);
Joystick leftStick = new Joystick(1);
Joystick rightStick = new Joystick(2);
* This function is called once each time the robot enters autonomous mode.
public void autonomous() {
* This function is called once each time the robot enters operator control.
public void operatorControl() {
while (isOperatorControl() && isEnabled()){
drive.tankDrive(leftStick, rightStick);
Timer.delay(0.01);
* This function is called once each time the robot enters test mode.
public void test() {
Wait, what?
Unread 06-02-2013, 13:03
Flywheel Police
Re: Drive Issue
Change that to:
drive.tankDrive(-leftStick, -rightStick);
Now to confirm that I'm understanding, both sets of motors are spinning backwards, so the robot moves backwards. Or one set spins forward and one spins back?
Unread 06-02-2013, 13:04
Wait, What?
AKA: Jimmy
Re: Drive Issue
Originally Posted by notmattlythgoe View Post
Change that to:
It gives me an error when I try that.
Both are backwards.
Wait, what?
Unread 06-02-2013, 13:06
Flywheel Police
Re: Drive Issue
Try
drive.tankDrive(-leftStick.getY(), -rightStick.getY());
Unread 06-02-2013, 13:12
Wait, What?
AKA: Jimmy
Re: Drive Issue
Both are working now. Thank you very much!
Wait, what?
Unread 06-02-2013, 13:17
Flywheel Police
Re: Drive Issue
Moving in the right direction now but the right side is not moving.
No problem, just so you have an understand of what you just did. The .getY() method returns the value of the joysticks Y axis(forwards and backwards). The - inverts whatever value that it is attached to.
