Go to Post You must have a base on which to stand. Knowledge is the base that wisdom stands on. - Steve W [more]
  #31   Spotlight this post!
Unread 05-02-2013, 21:22
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
Re: Team 2992 - 30 pt Climber - Top target dumper
Originally Posted by Jon Stratis View Post
The process originally described was to load tanks during the match, which would imply that the robot (including battery and cRio) were not part of the process, thus illegal. I would still be extremely concerned about safety, even if everything was loaded up from the robot. That safety concern (handling and mounting pre-charged storage tanks) could very well be enough to cite R08.
Yeah, you're probably right with that safety concern. It'd probably be an inspector's call, which you are and I'm not, so I'll take your word on how big a concern that is.
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
  #32   Spotlight this post!
Unread 06-02-2013, 07:36
sircedric4's Avatar
sircedric4 sircedric4 is offline
AKA: Darren
no team (The SS Prometheus)
sircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond repute
Originally Posted by Rhelik View Post
I am concerned the way your dumper works that you won't actually get the points for all those discs.
...-Bernie
Thanks for the concern! The dumper design was updated since the simulation run. Our trapdoor only falls open to 45 or 60 degrees depending on tests this weekend so that the frisbees all slide out. We hope that the angle and sliding momentum will be enough to keep them from stacking higher than the target line.
On another note, I personally feel that is a stupid rule/interpretation. I figure there are only 6 frisbees that can score and as long as they are within the horizontal component of the target box they should count. It is not trivial to get them up there and it seems to penalize those that are trying for the hardest goal.
  #33   Spotlight this post!
Unread 06-02-2013, 08:35
Rhelik's Avatar
Rhelik Rhelik is offline
AKA: Bernard Trombley
FRC #0250
Rhelik is on a distinguished road
Darren,
Great to hear you've already tackled a rule that is clearly making a tough goal even tougher.
I like the way you've tackled this years challenge.
-Bernie
_____________________________
Bernard Trombley
bctrombley@gmail.com
Mentor: Team 250
  #34   Spotlight this post!
Unread 06-02-2013, 09:29
coldfusion1279 coldfusion1279 is offline
AKA: Mike
FRC #1279 (Cold Fusion)
coldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud of
Great job. My suggestion for the last two weeks is to beef up your drivetrain, if you can. Traversing the field to get colored discs will be the hardest part once you have a target on your back. It's nice to be able to plow through. Good Luck.
Cold Fusion's 10th Season
  #35   Spotlight this post!
Unread 06-02-2013, 09:56
mdituri's Avatar
mdituri mdituri is offline
r0b0t Girl Forever
AKA: Monique Dituri
FRC #3314 (Mechanical Mustangs)
mdituri has a brilliant futuremdituri has a brilliant futuremdituri has a brilliant futuremdituri has a brilliant futuremdituri has a brilliant futuremdituri has a brilliant futuremdituri has a brilliant futuremdituri has a brilliant futuremdituri has a brilliant futuremdituri has a brilliant futuremdituri has a brilliant future
Just want to say..Excellent job. 50 points consistently is huge during qualifiers and will most certainly have you in the elims, maybe even doing the picking. Hope to see you at Worlds since we compete in MAR.
Week 1: Southwest Virginia Interdistrict
Week 2: Mount Olive MAR district event
Week 3: Pittsburgh Regional
Week 5: Montgomery MAR district event
Week 6: MAR District Championship
Week 9: Super Regional Championship North
It is impossible to teach without the courage to love, without the courage to try a thousand times before giving up.-- Paulo Freire
Montclair Society of Engineers Board of Directors, Secretary & Robotics Liaison
WiPro Science Scholar Fellow 2013-2015 & Chemistry Teacher - Clifton High
  #36   Spotlight this post!
Unread 06-02-2013, 10:11
GilaMonsterAlex's Avatar
GilaMonsterAlex GilaMonsterAlex is offline
Lead Team Mentor
FRC #3785 (Gila Monsters)
GilaMonsterAlex is an unknown quantity at this point
Very freaking cool! We spent a lot of time deliberating on what we wanted to do this year.
This an awesome robot.
2014 - AZ Regional Finalist
2013 - AZ Regional Finalist
2013 - AZ Gracious Professionalism Award
2011 - AZ Motorola Quality Award
  #37   Spotlight this post!
Unread 06-02-2013, 14:41
sircedric4's Avatar
AKA: Darren
A great suggestion and one we had planned to do, but our final weight and Cg requirements probably won't allow us to do much in this respect.
We are counting on the smaller perimeters, the safe loading zones, the pinning rules, and being able to drive under the pyramids to allow us to make the one trip across the field we need.
I don't envy the good frisbee shooters that may need to make multiple trips across the field.
  #38   Spotlight this post!
Unread 06-02-2013, 15:05
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Your robot is definitely awesome, but this post is even more impressive. It seems like you've really put a lot of thought into your entire strategy, both at the global level, and the step by step level, and for that I applaud you. Good luck wherever you end up.
  #39   Spotlight this post!
Unread 06-02-2013, 15:45
Bryce Paputa's Avatar
Bryce Paputa Bryce Paputa is offline
FF TSL: Frog Farce
FRC #0503 (Frog Force)
Bryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond repute
This is awesome, it was also our plan until we realized that only 1 or 2 robots can fit inside the pyramid at the top level...
This will be awesome in qualifications, but in eliminations it makes it so you cannot pick any other inside climbing team and have them climb. GL
  #40   Spotlight this post!
Unread 06-02-2013, 15:47
barn34's Avatar
barn34 barn34 is offline
Isn't this how Skynet got started?
AKA: William Barnickel
FRC #2481 (Roboteers)
barn34 has a reputation beyond reputebarn34 has a reputation beyond reputebarn34 has a reputation beyond reputebarn34 has a reputation beyond reputebarn34 has a reputation beyond reputebarn34 has a reputation beyond reputebarn34 has a reputation beyond reputebarn34 has a reputation beyond reputebarn34 has a reputation beyond reputebarn34 has a reputation beyond reputebarn34 has a reputation beyond repute
I definitely agree with this. We've discovered a similar challenge with this scoring strategy and I feel that this is an obsurd limitation. Like you said, getting frisbees in that 5 point goal is not trivial (it is, in fact, the most difficult goal to score in). Having another limitation to the effectiveness of tackling the toughest of challenges, head on, seems counter intuitive to say the least. Hopefully, a rule update will be released prior to competition that remedies this.
All-in-all, great design, guys! Very impressive, and good luck at the competitions!
  #41   Spotlight this post!
Unread 06-02-2013, 15:56
sircedric4's Avatar
AKA: Darren
While this is true, I would be willing to bet that the number of frisbee shooters to dedicated climbers will be at least 3 to 1. We figured that if we found a niche that we could do consistently then we would find ourselves 2 other partners to work with come eliminations.
We leave the entire autonomous to those floor feeders without getting in the way, and stay out of the way of others scoring. I would be willing to bet that the winning teams will have one floor pickup autonomous, two good scorers and 1 climber. Otherwise you end up getting in each others way and that can lower your scoring potential.
I think the GDC purposely built a game that will award a team of specializations as opposed to 3 good shooters. What is better a football team of all good quarterbacks, or one with a good quarterback, and good offensive lineman, and good receivers?
  #42   Spotlight this post!
Unread 06-02-2013, 15:59
Jaxom Jaxom is offline
AKA: Michael Hartwig
FRC #1986 (Team Titanium)
Jaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant future
Originally Posted by AllenGregoryIV View Post
In the past the rules have been such that you must use the battery you plan to use during the match. I haven't seen a Q&A about it this year, so I am not sure if that is still the correct ruling. R80 is unclear.
There is no rule that says you can't change batteries after filling up your tanks; see this post from Big Al: http://www.chiefdelphi.com/forums/sh...9&postcount=24
Mentor http://www.teamtitanium.org/
  #43   Spotlight this post!
Unread 06-02-2013, 18:43
MetalJacket's Avatar
MetalJacket MetalJacket is offline
Has read the 2014 manual
AKA: Jesse Gibson
FRC #2068 (The Metal Jackets)
Team Role: CAD
MetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura about
Originally Posted by JesseK View Post
It's also interesting to see that there haven't been any tangible claims (photos, video, sketches of ideas) of a corner-climber yet.
http://www.youtube.com/watch?v=Vjifzv5Oago
Not sure if you've seen this yet, or how tangible you consider it to be but it looks like this team has a corner climber.
Team Role = !artTeam
2011 - Logomotion
- Virginia Regional : Tournament Semi-Finalist, Gracious Professionalism Award
2012 - Rebound Rumble
- Chesapeake Regional : Tournament Finalist, Gracious Professionalism Award
2013 - Ultimate Ascent
- Virginia Regional : Gracious Professionalism Award
  #44   Spotlight this post!
Unread 08-02-2013, 10:08
frcchile's Avatar
frcchile frcchile is offline
FRC #2576
frcchile will become famous soon enough
We have completed enough of our robot to finally showcase how we are gonna climb to 30 pts and dump frisbees on the top for 20 pts.
This week we will be finishing the wiring and plumbing and doing the final Cg adjustments to make it work.
To begin, this link takes you to a simulation we performed on the CAD robot to show everyone how we expect it to climb.
http://youtu.be/l7z5QPjqEAk
Our other video shows us doing the first 2 levels to make sure that the robot, as built, performed as required. You will notice weight cupcakes zip tied all over the robot to make sure our robot is at the proper weight and Cg.
http://youtu.be/CbTblcCOoS4
We plan to have the robot climbing under its own brains this weekend and when we get video of that, I will post it to this topic.
Enjoy! We look forward to your comments and questions.
Hello, I want to know what type of piston did you use and its specifications?
I thank you and I await your reply!
  #45   Spotlight this post!
Unread 08-02-2013, 15:49
sircedric4's Avatar
AKA: Darren
2 inch diameter Bimba cylinders. If you do the math at 60 psi they can push 180 lbs and pull something like 155 lbs.
