Go to Post From a coaching standpoint, I can tell you...the coach is NOTHING without valuable scout information. If the coach is nothing, the robot is NOTHING. It all starts from the scouts...get your kids to see this. - Brandon Holley [more]
Unread 04-02-2013, 22:42
Walter Deitzler's Avatar
Walter Deitzler Walter Deitzler is offline
UAH Class of 2019
FRC #3397 (Robolions)
Walter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond repute
Changing Font size in Inventor?
To give to our welding sponsor, I am making a standard.idw technical drawing for each frame element. When printed, the text size is almost too small to read. Is there any way I can adjust it throughout the whole drawing, without having to change the font size of each dimension individually?
Thanks!
(Hanging out with my buddies at 610)
Robotics, it's not just a club, it's a career.
FLL Referee (2012-Present)
2014 Gateway Robotics Challenge winners (With 2481 and 1985)
2011 St. Louis Regional Winners (With 1985 and 3284)
2010 Highest Rookie Seed
I am the guy in the golden hat, say "Hi!" to me at WORLD CHAMPIONSHIPS!!!
Unread 04-02-2013, 22:46
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
Re: Changing Font size in Inventor?
Did you draw (for lack of a better term) each letter, or did you use the text command? If you used the text command it is as simple as going into your sketch and editing the size. If you "drew" them individually I am not sure I know how to help you.
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 04-02-2013, 22:51
UAH Class of 2019
These are the dimensions that inventor put in when I used dimension tool. I can change font size for free-form labels, but not for measurements that Inventor put in.
Unread 04-02-2013, 22:54
In that case, can you just edit those original dimensions to something of your liking?
Unread 04-02-2013, 23:33
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
I am not sure what the dimension text is derived from. Is it the sketch dimension or a dimension placed in the IDW environment? If you can send me the IPT and IDW file I will have a look.
Phil Dollan
Autodesk Inc.
Autodesk Inventor and Fusion 360
Unread 05-02-2013, 02:05
Garrett.d.w's Avatar
Garrett.d.w Garrett.d.w is offline
Build Lead
FRC #2733 (The Pigmice)
Garrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to behold
One thing that I noticed on my machine at least is that you have to set the page size right. My printer will scale print jobs to print on the page (8.5*11) so you have to make sure that the page in your IPT or IDW is set to whats loaded in the printer.
I played around with other ways to change the font size, but I didn't come up with any.
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
Unread 06-02-2013, 15:25
chiefsfan67's Avatar
chiefsfan67 chiefsfan67 is offline
AKA: Cake Jooper (Switch the C and J)
chiefsfan67 is a splendid one to beholdchiefsfan67 is a splendid one to beholdchiefsfan67 is a splendid one to beholdchiefsfan67 is a splendid one to beholdchiefsfan67 is a splendid one to beholdchiefsfan67 is a splendid one to beholdchiefsfan67 is a splendid one to behold
Easiest way to fix this is when you're in the .idw put down your first line of text, right click on it and then go to edit text style. From here you can change the size and font of the text. This will update all added text after this. (I'm working in inventor 2013)
