Go to Post Everyone needs to please stop now before Karthik starts singing. - dlavery [more]
Unread 05-02-2013, 21:19
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
inkspell4 will become famous soon enough
Vision Assistant
Does anyone know of a way to right all the code for image processing in vision assistant?
Then how could that be implemented in the labview dashboard?
Chesapeake Regional : 2013, 2012, 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
Unread 05-02-2013, 22:39
faust1706's Avatar
faust1706 faust1706 is offline
FRC #1706 (Ratchet Rockers)
faust1706 is infamous around these partsfaust1706 is infamous around these parts
Re: Vision Assistant
What do you mean by vision assistance? There are a multitude of ways a camera can help a team in this game. One would be calculating the center of the target then drawing a line on the screen down the middle from top to bottom, and when the center is on that line, the robot is aimed perfectly.
Unread 06-02-2013, 00:10
jesusrambo jesusrambo is offline
Self-Proclaimed Programmer Messiah
AKA: JD Russo
FRC #2035 (Robo Rockin' Bots)
jesusrambo is an unknown quantity at this point
Look in the menus, the vision assistant will export its script directly to a LabVIEW VI or to C++.
Unread 06-02-2013, 14:07
inkspell4's Avatar
Is there a way to do everything we need to find the center of the target and the distance to it built into vision assistant? And does anyone have a sample program they can post?
Unread 06-02-2013, 14:21
You should look at the Rectangular Target - 2013.lvproj example project. See Tutorial 8—Integrating Vision into Robot Code for detailed instructions. It's not the Vision Assistant, and it's not going to work with precaptured images unless you do some extra steps, but I expect it's what a lot of teams will be using.
Unread 06-02-2013, 14:49
inkspell4's Avatar
Our team is actually programming in java but looking to do vision processing with vision assistant on the dashboard is there no way to do this?
Unread 06-02-2013, 16:07
Well there usually is, and this case, ...
If you want to develop your own vision algorithm, you can use NI Vision Assistant, and generate either LabVIEW code to merge into the dashboard, or create C code to merge into your dashboard.
As Alan pointed out, much of the work has been done for you and you may want to at least look at the white paper and example to see how they compare to your ideas.
Greg McKaskle
Unread 06-02-2013, 17:03
inkspell4's Avatar
Where can i find the "whitepaper"?
Unread 06-02-2013, 21:50
inkspell4's Avatar
When you say whitepaper are you referring to screen steps live?
Unread 06-02-2013, 22:40
http://wpilib.screenstepslive.com/s/3120/m/8731
