Go to Post If this truly bothers you, you should do something CONSTRUCTIVE about it instead of whining about it - Jaine Perotti [more]
Unread 06-02-2013, 17:29
Reggie335 Reggie335 is offline
AKA: Reginald
FRC #4297 (WeNoRobots)
Reggie335 is an unknown quantity at this point
Front two motors will not wheels
My front two motors will not move but my two rear motors will. I have programmed all 4 motors into FRC LabVIEW, i have made sure that all wires for each motors are in their right place, and both front motors will not move at all and we are using Jaguars
Unread 06-02-2013, 17:34
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Re: Front two motors will not wheels
a couple of things.
1. post your code if you can. It will help folks see what you are doing.
2. do all of the jags lights go solid when you enable the robot? IF they continue to blink, you have something wrong. It may be as simple as your PWM's are in backward.
Check. and get back to us :-)
Unread 06-02-2013, 17:43
AKA: Reginald
which code like my begin vi. teleop or all of it
Unread 06-02-2013, 19:59
wilsonmw04's Avatar
Coach
All of it.
Unread 06-02-2013, 22:17
lorem3k's Avatar
lorem3k lorem3k is offline
1 + 1 = 0 (in Z/2Z)
AKA: Andy D.
FRC #1482 (Bishop Grandin Ghosts)
lorem3k is a splendid one to beholdlorem3k is a splendid one to beholdlorem3k is a splendid one to beholdlorem3k is a splendid one to beholdlorem3k is a splendid one to beholdlorem3k is a splendid one to behold
Make sure you have 12V of power going to the Digital Sidecar, not just 5V. We had a similar problem last year because we didn't give the Sidecar enough voltage.
Boo! Bishop Grandin High School / GM Canada / Tenaris
2013 Western Canada - Quarterfinalists (thanks 288/4719) / 2012 GTR West - Quarterfinalists (thanks 188/1075) / 2011 GTR East - Regional Winners (thanks 1114/1503)
Unread 06-02-2013, 22:54
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
inkspell4 will become famous soon enough
Originally Posted by wilsonmw04 View Post
All of it.
if you could post your begin.vi, teleop.vi and any others controlling the drive i think most of the problems if any could be found.
Chesapeake Regional : 2013, 2012, 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
Unread 06-02-2013, 22:56
brrian27's Avatar
brrian27 brrian27 is offline
the Mormon
AKA: Brian
FRC #2383 (Ninjineers)
brrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond reputebrrian27 has a reputation beyond repute
Put a voltmeter on the output terminals of the jags to see if they are working correctly. For us the jaguars go bad all the time. I'd recommend Victors in the future
team2383.com
2011-14: Student- Team 2383, the Ninjineers (2013-14: Drive Team Coach & 2014: Co-Captain)
5 Team Spirit Awards --- 1 Excellence in Engineering Award --- 1 Regional Finalists
Currently : Student- Brigham Young University
2015 SOUTH FLORIDA REGIONAL CHAMPS #BLUEBANNERYEAR ARCHIMEDES DIVISION FINALISTS
Unread 06-02-2013, 23:28
JV2073's Avatar
JV2073 JV2073 is offline
FRC #2073 (EagleForce)
JV2073 has a spectacular aura aboutJV2073 has a spectacular aura aboutJV2073 has a spectacular aura about
1. Post the code if you can.
2. Check if all three lights on the digital slidecard is green. If its not then you are giving it 5V which should be for the camera.
3. If you are moving a motor see if its a solid color or if its still binking yellow. If its blinking then the PWM wires are backwards.
4.If its says error 44037 then the PMW is not even on the correct places because it cant read it.
5. Make sure to make a new project in LABVIEW and then test it to see if its a mechanical or program problem
6. Look at the code error in diagnosis and look them up to start fixing them.
If you need any more help, please ask.
Unread 07-02-2013, 09:24
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
How are the lights on the Jaguars behaving?
