Go to Post "We don't build the robots, we build the robot builders." - [more]
Unread 06-02-2013, 18:03
2144 2144 is offline
FRC #2144
2144 is an unknown quantity at this point
Re: 2013 Vision Processing
Hi guys, jumping onto this thread, I have been having issues with adding in the Visual programming folder into my Labview Code.
I followed their instructions that are given in the RectangularTarget.vi and created a duplicate folder, and then pasted it into my Labview Code, however when I do so, it breaks the wiring in Robot Main.vi from DrvrStn Get Mode to Robot Mode above the case structure. When I try to rewire it, it says that I have the wrong type of wire. It does the same thing in the Begin.vi with the wire between the mode selector and the Robot Mode.
In short, replacing my code with the visual programming folder breaks wiring in the Begin.vi and Robot Main between the mode selector and DvrvStn Get Mode, respectively.
