Go to Post It's official: we've run out of things to talk about. - Jessica Boucher [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 06-02-2013, 18:08
snowballz snowballz is offline
FRC #4808
snowballz is an unknown quantity at this point
Exclamation I need a flashlight for our bot
I don't know where to get a flashlight for the robot, and i dont know what the specs of a good one is. PLEASE HELP
Unread 06-02-2013, 18:20
kjohnson's Avatar
kjohnson kjohnson is offline
Insert Clever Title Here
AKA: Kyle J.
FRC #1610 (BOT)
kjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond repute
Re: I need a flashlight for our bot
Some teams use flashlights, but this LED is available at AM and can be wired to your robot without modification: http://www.andymark.com/product-p/am-2089.htm
Unread 06-02-2013, 18:29
FRC #4808
so i can see this with my eyes right because we're not doing the autonomous part
Unread 06-02-2013, 21:06
ferret_guy ferret_guy is offline
AKA: Mark Omo
FRC #1703 (RATS)
ferret_guy is on a distinguished road
Yes it emits visible light
Unread 06-02-2013, 23:08
What do you want to use the flashlight for? The suggested "light engine" module provides wide angle illumination, perfect for use with the camera and the retroreflective goal borders. If you have different requirements, it might not be suitable.
Unread 06-02-2013, 23:15
FRC #4808
But we're not using a camera so would it still work?
Unread 06-02-2013, 23:30
Botwoon's Avatar
Botwoon Botwoon is offline
A.K.A. Matthew Ruane
FRC #0207 (Metalcrafters)
Botwoon will become famous soon enough
Retroreflective tape only appears lighted if you're looking at it from the same vector as the light source.
If you're doing what I think you're doing - trying to cast a relatively focused beam of light at the wall (not just the tape) to give your drivers a visual cue to indicate that they're on target - then no, it *probably* wouldn't..
Unread 06-02-2013, 23:33
FRC #4808
So what should I use then? I'm really sorry this is our first year
Unread 06-02-2013, 23:45
What you should use depends on what you want to use it for.
What do you want to use it for?
Unread 06-02-2013, 23:47
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
The OP wants a normal hand held flashlight, not a ring light or anything of that sort. Just wanted to clarify that for them
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 06-02-2013, 23:50
FRC #4808
I need something that can light up the tape and/or the area around it to give our drivers an idea of what they're aiming at
Unread 07-02-2013, 13:19
Orion.DeYoe Orion.DeYoe is offline
FRC #5413 (Stellar Robotics)
Orion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to behold
I think they're making a photon cannon...
Unread 06-02-2013, 23:52
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
inkspell4 will become famous soon enough
Without utilizing a camera you will not be able to use the reflective tape for what you need because the tape is retroreflective and not just reflective.
Chesapeake Regional : 2013, 2012, 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
Unread 06-02-2013, 23:54
FRC #4808
Like I don't need it to reflect I just need the area to be highlighted
Unread 06-02-2013, 23:59
So you basically just want to shine a spotlight in the direction your robot will be shooting?
If that's what you're trying to do, I suggest that you go flashlight shopping and find one that will work for your purposes. Then figure out how to power it legally, using the robot battery. You can also search the forum for the phrase "photon cannon" and maybe get some useful information.
