Go to Post When I mentor other people in programming... they either get pointers or they don't. - JamesTerm [more]
Unread 17-02-2012, 01:32
Joining the 900 Meme Team
FRC #0079
Warning: module holds reference to undefined symbol
While using Command Based Robot code I am getting the following error for each of my SubSystems
Warning: module [what I guess is an address in the symbol table] holds reference to undefined symbol [some number]CommandBase[Hex Value][name of symbol]
It then unloads the FRC_UserProgram.out causing a "No Robot Code" error.
Now the weird part, on a whim I changed the reference name (via the refactor menu) to something different. The error never changed. I searched for every instance the old name and none were found. This makes me question whether the updated code is being put onto the robot.
Any advice is appreciated.
Unread 17-02-2012, 06:55
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Re: Warning: module holds reference to undefined symbol
I'm not sure what help I can be - we don't use the command-based robot code. No doubt you know this but for the students out there - when we load kernel modules we use a dynamic linking loader but it is a single pass linker unlike the multi-pass linker we use to combine object modules and libraries form the command line. The process is much like loading a kernel module in Linux or a dynamic driver in Solaris.
So you are loading a kernel module that has a symbol in it that cannot be resolved against the symbol tables of all modules (and the kernel) already in memory. From your description, the symbol is a mangled C++ symbol.
When you build the command-based code, do you need to pre-link a library with your application code (with a -l parameter on the linker command line)? I will look at the command-based stuff and get back to you.
HTH
Unread 17-02-2012, 07:05
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
The command-based robot does not link to any extra libraries, only to WPILib.a, so that is not the problem. Do you include a customized version of CommandBase.cpp in your project? I see that class has 3 static members - init, OI and examplesubsystem)? Do you have instances of all 3 declared somewhere?
Unread 17-02-2012, 09:00
FRC #0079
CommandBase.cpp has been modified to look like:
#include "CommandBase.h"
#include "Commands/Scheduler.h"
CommandBase::CommandBase(const char *name) : Command(name) {
CommandBase::CommandBase() : Command() {
// Initialize a single static instance of all of your subsystems to NULL
OI* CommandBase::oi = NULL;
DriveTrain *CommandBase::chassis = NULL;
Elevator *CommandBase::elevator = NULL;
Intake *CommandBase::intake = NULL;
Shooter *CommandBase::shooter = NULL;
void CommandBase::init() {
    // Create a single static instance of all of your subsystems. The following
	// line should be repeated for each subsystem in the project.
	//examplesubsystem = new ExampleSubsystem();
	chassis = new DriveTrain();
	elevator = new Elevator();
	intake = new Intake();
	shooter = new Shooter();
	oi = new OI();
#ifndef COMMAND_BASE_H
#define COMMAND_BASE_H
#include "Commands/Command.h"
#include "Subsystems/DriveTrain.h"
#include "Subsystems/Elevator.h"
#include "Subsystems/Intake.h"
#include "Subsystems/Shooter.h"
#include "OI.h"
 * The base for all commands. All atomic commands should subclass CommandBase.
 * CommandBase stores creates and stores each control system. To access a
 * subsystem elsewhere in your code in your code use CommandBase.examplesubsystem
class CommandBase: public Command {
public:
	CommandBase(const char *name);
	CommandBase();
	static void init();
	static DriveTrain *chassis;
	static Elevator *elevator;
	static Intake *intake;
	static Shooter *shooter;
	static OI *oi;
#endif
Unread 17-02-2012, 09:23
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
That looks correct to me. Are all your subsystem classes complete or stubbed out?
Maybe try commenting out your additions till the module will load?
Unread 17-02-2012, 09:33
FRC #0079
They are indeed all stubbed out, the Create New SubSystem option in the context menu on the project tends to create fully stubbed out subclass of SubSystem.
I attempted the commenting out solution, none of the modules would load.
Unread 17-02-2012, 09:38
Jared Russell's Avatar
Taking a year (mostly) off
In this thread from a couple years ago the poster had a similar problem. For him, doing a clean reinstallation of WindRiver and all the updates fixed the issue. I would try installing WindRiver to its default directory for good measure.
Unread 17-02-2012, 09:40
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
Time to check with the author I reckon - perhaps try the nmppc utility and see if you can identify the unmangled symbol name? Is the 4 Feb update required to support the command-based templates? And if so, is your development environment up to date?
Unread 17-02-2012, 09:44
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
Where in the project do you right-click? I don't see the "Create New SubSystem" option.
Unread 17-02-2012, 09:45
FRC #0079
There is additional software you have to install (see the WPILib Cookbook for instructions). You click on the project name.
Unread 17-02-2012, 10:11
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
Hey - we do something like this but it is all home brewed. It cleanly separates the behaviors into classes/tasks though and uses a message passing mechanism to isolate each function. It makes life much easier for the student programmers, they can focus on simple tasks as if they were a single program.
PM me an e-mail address and we'd be glad to share the current code with you.
Unread 06-02-2013, 19:26
scottbot95 scottbot95 is offline
FRC #1388 (Eagle Robotics)
scottbot95 is an unknown quantity at this point
have you declared all the static members somewhere other than the class definition? it's a dumb problem with c++ but if you dont, the compiler wont actually create a symbol for the static class member.
Unread 07-02-2013, 00:57
bob.wolff68's Avatar
bob.wolff68 bob.wolff68 is offline
Da' Mentor Man
FRC #1967
bob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nice
I'll throw my 2 cents in. We've had some whacky problem in the past which were never fully explained, but sometimes doing a Project->Clean... will rinse out the garbage and get you back to sanity. I would suggest doing it as there should be no ill effects from a clean at all and only potential up-side.
bob
Bob Wolff - Software from the old-school
Mentor / C / C++ guy
Team 1967 - The Janksters - San Jose, CA
Unread 10-02-2013, 02:59
enrique's Avatar
enrique enrique is offline
FRC #1251 (Tech Tigers)
Team Role: Electrical
enrique will become famous soon enough
Send a message via Yahoo to enrique
I'm having the same error. I thought it was because of a class I made for a sensor, but I removed the class and the error continues. Warning: module holds reference to undefined symbol round. In debug I get the screen attached.
Unread 10-02-2013, 10:46
enrique's Avatar
Don't know if this helps, but on my error it had to do with the math.h include. Even though winriver has it and it has the round feature. I think the crio has something different. Either ways I made my own round function and it worked fine. Your error is wpilib related. I'm thinking maybe if you run the winriver update and format the crio, maybe the wpilibs will be in sync.
