Go to Post P.S. Who doesn't have CD as there homepage! (I mean, come on people. It's not like there's anything else to do on the net... :)) - Ryan M. [more]
Unread 04-02-2013, 18:36
Team3763 Adam Team3763 Adam is offline
Lead Programmer
FRC #3763 (4H WildCards)
Team3763 Adam can only hope to improve
Exclamation Servo motor?
So my team and I were trying to figure out how to program a servo motor in teleop where when we push button 1 the servo spins its full range then once the button is released the servo returns to 0° automatically. No clue how to program this and any help given would be great
Unread 04-02-2013, 18:53
James H James H is offline
FRC #4256
James H is an unknown quantity at this point
Re: Servo motor?
This depends on the rate at which you want this to happen at. As fast as possible is pretty easy since the servo just needs you to give it an angle and it does the rest unlike other motors that need a speed input. So before I can give you a definite answer, do you have a rate at which you would like the servo to move?
Unread 04-02-2013, 21:01
Re: Servo motor?
Assuming you don't care about slowing down the servo's motion, what you want to do is pretty easy. Use a joystick button to select between 0 (when false) and 180 (when true), and feed the selected value to a Gyro Set Angle.
I think the default maximum is actually only 170 degrees. You can change it to match the servo you're using when you Open it.
Unread 06-02-2013, 17:59
Lead Programmer
Re: Servo motor?
We don't care about speed, and we're just trying to get the servo to go from button not pushed: 0°; button pushed 180°, 170 if this is max.
Below is the code we have so far, it's from an example I believe.
Unread 06-02-2013, 19:15
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Re: Servo motor?
The code looks good to me. Another thing to remember is that the servo needs power applied to it, too. There has to be a jumper across the two pins directly next to the PWM port the servo is plugged into.
I'm right 90% of the time, so why worry about the other 3%?
Unread 06-02-2013, 19:43
Lead Programmer
Re: Servo motor?
There's a jumper, and it's wired in PWM 4. We're currently having problems with our Digital Sidecar. There's a thread posted here http://www.chiefdelphi.com/forums/sh...d.php?t=112925
Unread 06-02-2013, 21:05
Cecil's Avatar
AKA: Alex Hummel
Re: Servo motor?
Well.. That opens up a whole 'nother bag of worms. Based on what you have said from your last thread, have you tried swapping the cable from the cRIO to the digital sidecar with a known working one? Remember that last year's ribbon cables shipped assembled backwards, which would screw up a bunch of things.
Unread 06-02-2013, 23:13
Lead Programmer
Re: Servo motor?
We've differentiated between the round and flat cables, however I do believe the issue MAY be with DS (digital sidecar) as it wasn't receiving full power. Tomorrow I will make adjustments and take photo pictures then upload them here. Here's to hope!
Unread 07-02-2013, 09:25
Cecil's Avatar
AKA: Alex Hummel
Re: Servo motor?
I saw the other thread, and I can't believe I made the fundamental mistake of not suggesting power to the Digital Sidecar. Hopefully applying power will fix everything easily.
