Go to Post I've completely figured [the hint] out: Robots will have to move around, and also displace objects in order to score points. What do I win? - pfreivald [more]
Unread 06-02-2013, 23:07
mocibot's Avatar
mocibot mocibot is offline
FRC #1829 (Carbonauts)
Team Role: Student
mocibot is just really nicemocibot is just really nicemocibot is just really nicemocibot is just really nice
pic: 1829 Carbonauts Teaser
Unread 06-02-2013, 23:08
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Re: pic: 1829 Carbonauts Teaser
Frisbee pickup. Push this onto a Frisbee from the top, and it pops into a vertical hopper.
-Plutarch
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Frisbee hopper? (Or above)
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 06-02-2013, 23:09
Austin2046's Avatar
Austin2046 Austin2046 is offline
Design, Strategy & Scouting Mentor
FRC #2046 (Bear Metal)
Austin2046 has a spectacular aura aboutAustin2046 has a spectacular aura about
clearly their climbing mechanism
Unread 06-02-2013, 23:10
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
inkspell4 will become famous soon enough
You may want to check the rules I'm not sure if an arc reactor wold be allowed on the robot
And how are the metal brackets mounted to the board?
Chesapeake Regional : 2013, 2012, 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
Unread 06-02-2013, 23:22
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
those are two different halves to your shooter, I believe I can see two cuts in each of the circle's. making them halves. the flanges are to contain the top of the Frisbee and the middle circle and the bottom of the outside circle are rails for the Frisbee to ride on.
/thread
NEXT!
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 06-02-2013, 23:25
Upon closer review of the picture, there are only cuts on the one side of each circle.
Therefore it is a hopper that helix's us to your shooter.
yes??
2013-Present
2010-2013
Unread 06-02-2013, 23:26
inkspell4's Avatar
yes??
Or the method of cutting out the center of each circle required them to make the cuts
Unread 06-02-2013, 23:43
have you heard of a jig saw? and drilling a hole first?
2013-Present
2010-2013
Unread 06-02-2013, 23:48
inkspell4's Avatar
Yes!
I just did that earlier today. It was just an idea.
Unread 07-02-2013, 00:01
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
This is obviously a holder for a frisbee sample. I assume that you are using a colored frisbee as a physical sample on your robot to calibrate your vision system to the changing lighting conditions on the field, similar to the calibration unit on the Mars Science Laboratory rover.
Unread 07-02-2013, 00:05
inkspell4's Avatar
Would a frisbee mounted onto the robot mean they could only hold 3 frisbees for use in shooting?
Unread 07-02-2013, 09:29
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Look at the writing on the protective covering on the polycarb. Using that to guess the scale, it seems like it's far larger than a single frisbee.
I'm going with some sort of spiraling and/or rotating frisbee storage.
Unread 07-02-2013, 14:16
mocibot's Avatar
Team Role: Student
Rivets
You'd like to think so!
yes??
It does look like it, doesn't it?
Well, now that's an idea. Might have to let vision tracking people know about that one.
That seems to be the popular idea here, maybe it is...
Good luck, stay safe, learn new things, and have fun!
I'm a student, because I don't fit in any one category.
Unread 08-02-2013, 20:56
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
It is a Frisbee pick up device that works like one of those bags that pick up golf balls. We prototyped an identical device using surgical tubing going around the bucket.
