Re: pic: 3992 Drive Train
My team had direct driven Macanum's (6in from CIMple boxes) in 2011 and we could only drive forward/backwards and turn, we couldn't strafe because we didn't have enough torque to turn the wheel opposite to eachother. PLEASE CHECK YOUR DRIVE NOW!!! Before it's too late and you're a sitting potato on the field. |
Did you not have enough torque to strafe period? When we tested this on the previous drivetrain, it succesfully strafed, albeit it a slight angle rather than directly perpendicular. |
There was not enough reduction, usually people would use toughboxes on macanum's we were dumb and didn't did you have 150lbs on that robot? that's when you need to the torque. |
What about putting a Mini-CIM in each gearbox for additional torque? Or RS-775's on CIM-U-Lators?
Thats not a bad idea, and probably the fastest switch, but switching to Toughbox Mini's would give you the best results.
We'll test with this and a heavy load on the chassis and see if the results are poor enough to warrant the switch. If anything, I think we'll switch to toughbox Nanos. The mini has a front plate bigger than our actual plate so it'd be an odd fit. |
#7
