Go to Post Mentors are the guardrails: Show the students how to do what they need to do, Step back and let the students do what they need to do, Nudge them back on course when they need a nudge, Insist, when necessary, that no one tries to juggle the chainsaws - gblake [more]
Unread 06-02-2013, 23:45
Greycrazygamer's Avatar
Greycrazygamer Greycrazygamer is offline
FRC #2761
Greycrazygamer is an unknown quantity at this point
CAN Encoder Programming problem
we are designing a pivot drive system this year for our robot, however i am running into some problems with the code. We integrated the example CAN position.vi example from labview into teleop, however, when running the code, our AMS as514sb encoder will go to a certain value, then reset to 0. for example, if i set its position to 2 rotations, it may go to 1.78, then reset back to 0. this produces an effect of the motor continuously running, attempting to reach 2.00, but failing. interestingly, the encoder pulses seems to control the range of value we can move between before the value resets to zero. We are also running a US digital encoder to turn our wheels forward/back and we are having no problems with this encoder. i know the the AMS can utilize must higher pulses per minute than the US, but im not sure if that should effect the code.
Unread 06-02-2013, 23:55
Re: CAN Encoder Programming problem
The AS5145B is intended to be used as a rotational position encoder, not a quadrature encoder. How do you have it connected? How are you reading its value?
Unread 07-02-2013, 00:14
ILikePizza555's Avatar
ILikePizza555 ILikePizza555 is offline
AKA: Isaac Avram
FRC #2761 (CN Ironhorse)
ILikePizza555 is an unknown quantity at this point
I'm from the same team as CrazyGamer and we are working together on this.
This is how we wired it:
Spoiler for Wiring:
PONIES ARE STOOPID MAGIK -Heavy
Unread 07-02-2013, 00:15
AKA: Isaac Avram
This is how we coded it:
Spoiler for code:
Begin.vi:
Cust M. - Open vi:
Cust. M. - EncodeMotor:
Teleop:
Unread 07-02-2013, 08:08
On the sensor, I see six wires: two red, two white, and two black. On the Jaguar, I see five: one each of red, white, and black, and two gray. What happens to the wires between the two devices?
You apparently have something connected to the "I" (index) pin of the Jaguar's encoder input. A signal on that pin will reset the count. Try just removing that connection and see if the count starts doing what you expect.
Unread 07-02-2013, 23:01
AKA: Isaac Avram
The wire leading that plugs into (-) on the Jag gets split into two and goes into gnd and Csn on the encoder.
