Go to Post It would be a (relatively) level* playing field *...though it seems like the actual field will be anything but level. - Jacob Bendicksen [more]
Unread 06-02-2013, 13:13
SoccerTaco's Avatar
SoccerTaco SoccerTaco is offline
Mentor, Volunteer
AKA: Steve Parham
FRC #3824 (roHAWKtics)
SoccerTaco will become famous soon enough
pic: Team 3824 Chassis Pic 2
Unread 06-02-2013, 13:16
Bstep's Avatar
Bstep Bstep is offline
FRC #1983 (Skunkworks Robotics)
Bstep is a glorious beacon of lightBstep is a glorious beacon of lightBstep is a glorious beacon of lightBstep is a glorious beacon of lightBstep is a glorious beacon of lightBstep is a glorious beacon of light
Re: pic: Team 3824 Chassis Pic 2
That looks fantastic! How light is it? Do you save much weight by using the carbon fiber? It looks like you have a sheet of solid aluminum on the base, depending on how thick it is you may want to cheese it out. If it's thicker than 1/32 you might be using up all the weight you saved by going carbon. Did you purchase the frame components that way or did you have them custom done?
Unread 06-02-2013, 14:57
Brandon Zalinsky's Avatar
Brandon Zalinsky Brandon Zalinsky is offline
Roaming GeorgiaFIRST MC
AKA: The Mecanum Man
FRC #1058 (PVC Pirates)
Brandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant future
I just looked at that, I am 95% sure that it is not aluminum. It is delrin or some other polycarb. If you look closely, you can see patterns and drawings on it, showing that it's just delrin with the paper protective coating still on it.
Also, I just would like to clarify on something here, are your wheels inside those tan blocks? If they aren't, you might have a problem with frame perimeter and bumper legality. I'm guessing the frame is 24x32, which is right at 112" limit. If the wheels are supposed to be outside, and my guess about frame perimeter is true, you might want to read this thread, because you'd be in trouble:
http://www.chiefdelphi.com/forums/sh...hlight=mecanum
This is the rule of why the wheels/axles can't stick out R04: In the STARTING CONFIGURATION, no part of the ROBOT may extend outside the vertical projection of the FRAME PERIMETER, with the exception of minor protrusions such as bolt heads, fastener ends, rivets, etc.
Great work, guys, and have fun this year!
This is our Robot. There are many like it, but this one is ours.
Measure twice, cut once, curse, buy more, and cut again.
2014- Excellence in Engineering (UNH), District Chairman's Award (NU), #8 Quarterfinalist (NECMP), Winner (Mainely Spirit)
2013- Semifinalists (Battlecry@WPI) Winner (Mainely Spirit)
2012- Regional Chairman's (GSR), Finalists as the #11 Alliance Captain (Battlecry@WPI)
2011-Xerox Creativity Award (GSR), Semifinalists (GSR) Innovation in Control (Virginia)
2010-Champion (GSR), Undefeated (Chesapeake), Coopertition Award (Chesapeake), Quarterfinalists (Galileo) 8th AC (IRI)
2008-Undefeated (GSR), Xerox Creativity Award (GSR)
Unread 06-02-2013, 16:58
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Going off of the compressor (6") I was able to figure that the frame is roughly 22 inches wide. If a guard was added around the wheels on each side that was 3 inches, the width would then be bumped up to 28 inches. This would make the whole frame 28" x 28". This frame could very well be legal if something was added to make the wheels on the inside. Also the shafts look a bit to long so they could most likely be chopped which would give more wiggle room.
Unread 06-02-2013, 18:34
I did the same thing with the compressor and thought it was 24." Either way.
Unread 07-02-2013, 00:04
SoccerTaco's Avatar
Mentor, Volunteer
AKA: Steve Parham
Brandon you are correct that the electronics are mounted to a piece of Lexan, not aluminum.
Mike was right on the money with the measurements. It is ~28 inches long and with the brackets that will go around the wheels, it will be ~28 inches wide and the shafts as is are a tad long. It will be tight, but we are all too aware of the 112 limit and are focused on making sure we are within it, and of course with legal bumpers also.
Unread 07-02-2013, 00:07
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
inkspell4 will become famous soon enough
Are you attempting a mechanim drive and are you using direct drive off the cims?
(Sorry if i misspelled that)
I saw the wheels in the background.
Chesapeake Regional : 2013, 2012, 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
Unread 07-02-2013, 00:28
SoccerTaco's Avatar
Mentor, Volunteer
AKA: Steve Parham
Hi inkspell - yes we are using mecanums and are using the Banebot gearboxes with them.
Unread 07-02-2013, 08:05
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
A work of art! What is the frame material used where you mounted the CIMs?
Unread 07-02-2013, 10:20
SoccerTaco's Avatar
Mentor, Volunteer
AKA: Steve Parham
Thanks Tim! Those gold parts where the CIMs are mounted were printed and are ULTEM.
Unread 07-02-2013, 14:09
protoserge's Avatar
Ah! I was thinking they looked printed...
