Go to Post the jocks may have muscle, but we have extruded aluminum :D - [527]phil [more]
Unread 07-02-2013, 00:24
Best Available Data
FRC #1778 (Chill Out!)
Re: Bonding polycarbonate to polycarbonate
Originally Posted by Akash Rastogi View Post
Ian, I've used this stuff for projects at home as well as the Loctite one, both work exceptionally well. Both this and the Loctite require the applicator gun.
http://www.walmart.com/ip/Devcon-Pla...er-ii/15632453
Use: http://www.youtube.com/watch?v=AHMykiX_YEQ
That mixer gun is genius. Having taught many people to use epoxy, I've had plenty of people tell me that "that stuff is garbage! doesn't stick at all!"
Does it dry fairly clear? Being a see-through structure I have been fretting over how to make the joints not look like garbage. I've asked Pinecone as well, will report back what he recommends being from the land of plastic.
Unread 07-02-2013, 01:18
bhumudar's Avatar
bhumudar bhumudar is offline
Mentor/Programming/Electrical
AKA: Bryant Humud-Arboleda
FRC #0714 (Panthera)
bhumudar is on a distinguished road
Another option is to heat the sheet with an acetylene torch and bend it on a vice. My team used this method on our robot last year for one of our components. Although this only really works for certain applications. If you don't need absolute precision, then this is a great way to go.
Stevens Institute of Technology
B.A - Electrical Engineering 14'
Mentor - FRC 714 (2012-Present)
Student - FRC 714 (2009-2010)
2013 Bridgewater-Raritan Winners (Thanks 1676 & 3314)
2012 MAR Regional Championship Judges Award
2012 Mount Olive District Excellence in Engineering Award
2012 Chesapeake Regional Finalist (Thanks 2068 & 358)
2012 Hatsboro-Horsham District Gracious Professionalism Award
Unread 07-02-2013, 06:32
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
The Loctite plastic bonder doesn't work well for polycarbonate sheets in my experience.
You want Methylene Chloride. It can be expensive, but you don't need a lot to make the bond. You will need a syringe to put drops of material along the surfaces to bond.
http://www.ehow.com/how_5686551_glue...ate-sheet.html
http://www.ehow.com/how_6635889_glue-lexan.html
http://www.mcmaster.com/#catalog/119/2120/=ldfxxn would need some additional chemicals added to the mix to make it easier to work with.
I've had experience with Weld-On #3 such as this: http://www.eplastics.com/Lexan_Polycarbonate_Glue
Unread 07-02-2013, 07:22
DELurker DELurker is offline
Former Engineering Mentor
AKA: William Lydick
no team (n/a)
DELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant future
A lot of very good information about using polycarbonate can be found here: http://www.curbellplastics.com/techn...e-makrolon.pdf
They have all sorts of information about bending, heating, forming, gluing, melting, folding, spindling, mutilating, and abusing polycarb.
With 1370 --
2012 Rutgers District Event Champions with 1676/56
2012 Lenape District Event Finalists with 2191/1691
2013 TCNJ District Event QuarterFinalists with 1143/4750, Gracious Professionalism Award
2013 Bridgewater-Raritan District Event Semi-Finalists with 4285/223
2013 MAR Championship Finalists (Backup) with 222/11/1403; Gracious Professionalism Award
Unread 07-02-2013, 07:28
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
I've had experience with Weld-On such as this: http://www.eplastics.com/Lexan_Polycarbonate_Glue
Methyl chloride works great, but it's really nasty stuff. I wouldn't reccomend using it without proper ventilation and personal protestive equipment, such as a respirator. Read up on exposure to it before considering using it.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 07-02-2013, 08:59
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
I would also second methyl ethyl ketone/Methyl chloride.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 07-02-2013, 11:41
AKA: William Lydick
no team (n/a)
I would strongly suggest reconsidering MEK and Methylene Chloride unless you have a really well ventilated area to work in and respirators to use.
http://www.sciencelab.com/msds.php?m...8&code=SLM2677
http://www.sciencelab.com/msds.php?msdsId=9927358
I have actually worked with both and found that I was especially sensitive to the vapors from each (ie - above the norm). You may want to look at a clear urethane adhesive or something similar.
Of course, I have to ask... for what purpose are you adhering these two parts together? Is there an opportunity to use a mechanical fastening instead?
With 1370 --
Unread 07-02-2013, 12:58
Best Available Data
It is a thin wall tabbed construction hopper that I intended to make out of plywood (which I know how to glue!) -- but the team wanted to make it clear for polycarb for looks. I could add larger tabs and put in some brackets, but I would rather not (mostly for looks). If adhesion turns out to be really difficult, I will probably end up doing that.
Unread 07-02-2013, 15:43
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Try using rivets and polycarb/alum angle. If it's thin enough you can bend it with a press brake.
High bond double back tape will also work.
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 07-02-2013, 15:56
AKA: William Lydick
no team (n/a)
You could take a piece of 1/16" polycarb (we did this at one point last week), bow it around into a hopper and put two mounting screws through the overlap into your frame, making it sit in place but still look kinda cool...
With 1370 --
Unread 07-02-2013, 16:22
Andy A. Andy A. is offline
Getting old
FRC #0095
IPS Weld-On #16 works pretty well on polycarb. #'s 55 and 58 work even better. They're all 'solvent' cements, which likely means something like Methylene Chloride is the active ingredient. The nice part is that the heavier glue base is much easier to work with then a pure solvent.
I would not recommend using pure MEK or Methylene Chloride without a respirator and appropriate training. I use it at work but it's tricky stuff to use right and super toxic. Purpose made adhesives will give good results with far less risk and trouble.
Unread 08-02-2013, 16:41
AKA: William Lydick
no team (n/a)
I was looking around for something else and found IPS Weld-On #4 recommended with a needle bottle applicator. From McMaster-Carr, it would be 7517A1 for 4 oz of adhesive ($8.79, water-thin) and 1902T41 for the needle bottle ($6.67). Recommendations online are to clamp the parts together and run a very tight bead of solvent down the seam, letting the adhesive wick into the joint.
MSDS #1 - http://www.curbellplastics.com/techn...c-weldon-4.pdf
MSDS #2 - http://www.tapplastics.com/uploads/p...%204%20New.pdf
With 1370 --
Unread 12-02-2013, 10:16
Getting old
FRC #0095
The super thin glues are great for repairs of plastic parts because, as you say, you can let it wick into joints or cracks. The problem is that the thinner the glue the harder it is to control and the less tolerant it is of less then perfect fit between parts. It's just really easy to dribble it where you don't want it, and the tiniest gap between your part will result in a poor bond.
I use straight MC for repair work and #16 for making new parts or where I need a degree of gap filling. As long as you're very careful and have very clean edges, the wicking method makes for a better looking joint, for sure.
Unread 12-02-2013, 11:49
thinker&planner thinker&planner is offline
AKA: CAAAAAD
thinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to behold
McMaster Carr has a bunch of adhesives that work great.
http://www.mcmaster.com/#adhesives/=lg4k4p
Just wondering, how about Aluminum to a rubber/urethane?
