Go to Post Celebrate your failures as well as your successes. - Taylor [more]
Unread 05-02-2013, 01:38
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
Plaction wheel shooter?
Hello,
My team is a bit behind schedule, and we have not finished our shooter yet.
We meant to use 8" AM pneumatic wheels directly driven from cim motors, but that caused very strong vibrations, which we didn't like.
We tested the same setup with 8" AM Plaction wheels and the vibration was considerably lower.
We would like to use the plaction wheels, but I'm afraid that they won't work as well as pneumatic wheels, and we won't be able to test for a few more days.
So... has anyone seen, used, tested or heard of an 8" plaction wheel shooter?
I'd like to try and gain some 2nd hand experience here in order to make the better decision early on.
Thanks,
-Leav
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 05-02-2013, 01:45
Garrett.d.w's Avatar
Garrett.d.w Garrett.d.w is offline
Build Lead
FRC #2733 (The Pigmice)
Garrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to behold
Re: Plaction wheel shooter?
We are running 6" performance wheels from am and are having good results with it (not half court shots, but we can score reliably). I'd assume that you'd see similar results with 8'' plactions.
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
Unread 05-02-2013, 01:54
Joe.Quirk Joe.Quirk is offline
FRC #1817
Joe.Quirk is an unknown quantity at this point
we used an 8 in plaction in our first round shooter test and it worked really well. we could make shoots consistently from the sides of the pyramid and behind it.
Unread 05-02-2013, 02:16
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Originally Posted by Leav View Post
Hello,
Thanks,
-Leav
You could try balancing the wheel as Andy talked about. And spin them a little slower, with both ends of the shaft supported.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 05-02-2013, 14:47
Orion.DeYoe Orion.DeYoe is offline
FRC #5413 (Stellar Robotics)
Orion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to behold
Hello,
Thanks,
-Leav
My team has done extensive prototyping in shooters this year. Although we haven't prototyped an 8 inch plaction wheel shooter we have messed around with other 6-8 inch "hard" (non-pneumatic) wheels. Through our observations it seems that you have to have some sort of give in the system (other than in the frisbee). When using pneumatic wheels the give is in the wheel. When using harder wheels you have to have give in the wall opposite your shooter. My team achieved this using a strip of pool noodle cut to a rectanglar cross-section of about 3/8 x 2 inches.
Unread 07-02-2013, 07:29
jkessler_22's Avatar
jkessler_22 jkessler_22 is offline
Motor Man
AKA: Joe Kessler
FRC #3015 (Ranger Robotics)
jkessler_22 is an unknown quantity at this point
Hello,
Thanks,
-Leav
Our team was using a Plaction wheel until the tread separated at the stapled connection and gave one of the mentors a pretty nasty "rug burn". We went to the pneumatic wheels and balanced them initially by adding 0.75 oz of automotive stick-on weights (Harbor Freight has them) to the opening in the hub directly across from the valve. That seemed to work much more smoothly, but we will probably try to fine tune the balance before competition.
Unread 07-02-2013, 09:46
GilaMonsterAlex's Avatar
GilaMonsterAlex GilaMonsterAlex is offline
Lead Team Mentor
FRC #3785 (Gila Monsters)
GilaMonsterAlex is an unknown quantity at this point
We are using 8" FIRST rubber wheels with added on belting, and these work great. It was not much different than the pneumatic wheels as far as distance goes. We also mount them low on the frisbee.
2014 - AZ Regional Finalist
2013 - AZ Regional Finalist
2013 - AZ Gracious Professionalism Award
2011 - AZ Motorola Quality Award
Unread 07-02-2013, 10:08
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
Alex,
What belting are you using, and how did you mount it to the wheel? We might want to do something similar, but I'm wondering about the safety issues that others have mentioned (tread tearing off at high speed). What is the highest RPM you have tested with this belting?
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
Unread 07-02-2013, 10:31
thedude019's Avatar
thedude019 thedude019 is offline
When fit hits the shan
AKA: Luke
FRC #3260 (SHARP Robotics)
thedude019 is an unknown quantity at this point
just make sure the plaction tread is on correctly if not the tread can fly off and hit you like it happened to me and leave a nice mark
Unread 07-02-2013, 11:03
AKA: Gerry
Luke,
Did you find a way to install the plaction tread "correctly"?
Correct == Safe && Effective
Cal
Fairport, NY, USA
Unread 07-02-2013, 17:11
SailorDad's Avatar
SailorDad SailorDad is offline
AKA: Rob Peace
FRC #1123 (AIM)
SailorDad is an unknown quantity at this point
We're using AndyMark's pneumatic wheel and found it works well without the innertube and it doesn't require balancing.
Burke, VA
Unread 07-02-2013, 18:51
wonder-weasel's Avatar
wonder-weasel wonder-weasel is offline
AKA: Christa
FRC #0930 (B.E.A.Rs)
wonder-weasel is an unknown quantity at this point
We're using 8" plactions and are doing quite well with them. Our controls group has been using our prototype to gather some data as we haven't received our machined shooter parts yet. We've been shooting pretty accurately and distance wise, they're good.
Unread 07-02-2013, 19:47
S2K JDM's Avatar
S2K JDM S2K JDM is offline
FRC #1378 (Hilo Viking Robotics)
S2K JDM is an unknown quantity at this point
We are using a 6" performance wheel with the wedgetop tread and its pretty good. we can shoot half court reliably. also we riveted the tread on. there's no vibrations, and its super quiet.
Team 1378 Hilo Viking Robotics| student | 2007-2009
Team 1056 Warrior Pride| Alumni | 2009-2010
Team 1378 Hilo Viking Robotics| Mentor |2011-present
Unread 07-02-2013, 21:47
MrTechCenter's Avatar
MrTechCenter MrTechCenter is offline
INTENSITY
AKA: Harsharan "Harsh" Dhaliwal
FRC #2073 (Eagleforce)
MrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant future
We made a prototype shooter using an 8 inch plaction wheel a few weeks ago.
We have slow-mo video available here: http://www.youtube.com/user/EagleFor.../videos?view=0
We have changed our shooter design, but the plaction wheel worked fairly well.
2011 Sacramento Regional Finalists; 2011 MadTown Throwdown VIP Excellence in Engineering Award; 2012 Sacramento Regional Innovation in Control Award; 2012 Silicon Valley Regional Judges' Award; 2012 CalGames Autonomous Challenge Award; 2012 MadTown Throwdown Finalists; 2013 P0W3RH0U53 PWNAGE Gracios Professionalism Award; 2014 Central Valley Regional Innovation in Control; 2014 Sacramento Regional Innovation in Control; 2014 Curie Division Gracious Professionalism Award; 2015 Sacramento Regional Innovation in Control
Unread 07-02-2013, 23:52
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
Where exactly did you add the weights?
When you say opening across from the valve stem, does that mean on top of the hub, or in between the spokes?
FTC Teams 5257, 6568 & FRC Team 3992
2014 FTC WORLD CHAMPIONS
14 Trophies in 3 Years
