Go to Post Long Live Gracious Professionalism, and long live F.I.R.S.T. - Matt Krass [more]
Unread 06-02-2013, 20:00
teets teets is offline
FRC #3070
teets is an unknown quantity at this point
use of fans on bot
so does anyone know whether or not we are allowed to use fans on the bot. No not the small computer fans i'm talking large industrial fans. Thank you.
Unread 06-02-2013, 20:12
Re: use of fans on bot
If it uses legal motors, and is properly enclosed so safety is not compromised, you should be just fine.
However... I do want to note that air wall tactics have been discussed a number of times, and the odds aren't necessarily in your favor, should you go for that method (though I can think of a couple of fans that might be able to do some frisbee disruption and fit in the robot size).
Unread 07-02-2013, 02:18
TheMadCADer TheMadCADer is offline
TheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant future
It could be the ideal defense against a hypothetical full-court shooter. You have a long path that the disc has to travel, so even small changes in angle have a large change in the final location of the shot. Also, their robot would be stationary, so you can just sit in front of them rather than chase after them.
Unread 07-02-2013, 08:58
As Eric pointed out, the fans you describe may only be used with legal motors.
Unread 07-02-2013, 09:01
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Fans on robots are not without precedent. These guys won the inaugural DC regional and were finalists at BMR. Not too shabby.
Hi!
Unread 07-02-2013, 12:29
neshera's Avatar
neshera neshera is offline
Nesher G. Asner
AKA: Nesher G. Asner
FRC #1625 (Winnovation)
Team Role: Parent
neshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud of
Our robot used fans in the Lunacy game, to try to help push the robot on the slippery regolith surface. This was quite legal, with the proper caging for safety. Having said this, it was done with a considerable amount of consternation on the part of some people (I'm with you, Kris! )
I'm still wondering if the ventilation systems at any of the venues will mess with long disc shots.
Do not panic! All is well!
- Kevin Bacon in Animal House
Unread 07-02-2013, 12:36
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
I still have nightmares about team 45's fan from Lunacy...
In all seriousness, make sure that if you put defensive fans on your robot that they use legal motors and the prop/blades/whatever are properly enclosed/protected. If you want a challenge make an effective version of the Dyson Air Multiplier.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
