Go to Post Dedication to FIRST gets more challenging as life gets more complicated but the rewards are SOOOOO worth it! - Sean Schuff [more]
Unread 22-01-2003, 15:28
Steven Carmain Steven Carmain is offline
Bit Twiddler
FRC #2832
Steven Carmain will become famous soon enough
Programming Port
Has any of you teams figured out how the programming port can help your robot performance?
The only thing I can think of is using DEBUG statements in the code, and then you custom circuit board can use the input. The problems with this is that you slow down your code greatly, and you have to make a circuit that can decode your DEBUGS and make it in less than 4 weeks. Then you would have to feed your outputs to the switches in the RC or feed it back through the programming port, and then download your code again. I think it would be faster just to do everything in the code and don't fool with a circuit.:
So is it even worth all this hassle?
Fried program slots? Jeff Waegelin Programming 18 19-03-2003 18:08
Horror Story - Laptop com port again Lloyd Burns Programming 3 17-03-2003 07:33
Dashreader.dll: A Visual Basic .NET user control to read the dashboard port Ameya Programming 4 12-01-2003 23:40
Change to Initializing Inputs and Outputs Jferrante Programming 4 07-01-2003 11:36
Programming Port GreenDice Programming 12 10-01-2002 09:14
