Go to Post Canadian teams would definitely be able to give some of the "big boys" a run for their money. Despite the fact that their money is worth more than ours... =) - Karthik [more]
Unread 07-02-2013, 13:08
Schnyde Schnyde is offline
FRC #2856
Schnyde is an unknown quantity at this point
How to UDP
My team (2856) wants to send process aiming data on the driverstation/dashboard and then send it back to the robot's cRIO (which runs java) using UDP. Everything I see involving this in threads seems to imply that UDP is a common way of sending data back to the cRIO; however, there doesn't seem to be anything that really says how to do this. I tried using the javadoc to learn, but when I did what it says to do I get a "'datagram' protocol not found" exception. Does anybody know how to UDP in java?
