Go to Post Only time will tell for sure, but it seems that the current software providers are hatching up a pretty good solution to the problem. - dlavery [more]
Unread 07-02-2013, 16:09
wag2625 wag2625 is offline
FRC #2625
wag2625 is an unknown quantity at this point
Driver Station User Messages Not Updating
Hello, we are currently working on vision tracking for our robot using Wind River C++. We were attempting to use messages as debugs and realized that we are not receiving updates in the 'User Messages' section of the Driver Station.
This is the code being used to send and update messages to the Driver Station:
dsLCD->Printf(DriverStationLCD::kUser_Line1, 1,"Message\n");
dsLCD->UpdateLCD();
The user message will sometimes print once when the code is first deployed, but will not continue to update after that. We have tried running this command at various points throughout the program without success.
Any ideas???
Unread 07-02-2013, 20:12
ekapalka's Avatar
ekapalka ekapalka is offline
FRC #3216
ekapalka has a spectacular aura aboutekapalka has a spectacular aura about
Re: Driver Station User Messages Not Updating
I'm not sure if this fixes your problem, but we've been printing data to the driver station like this:
//initialize
DriverStationLCD *dsLCD = DriverStationLCD::GetInstance();
dsLCD->Printf(DriverStationLCD::kUser_Line1, 1, "Here is some text");
dsLCD->UpdateLCD();
Wait(0.1);
or like this:
dsLCD->PrintfLine(DriverStationLCD::kUser_Line1, "Here is some more text");
dsLCD->UpdateLCD();
Wait(0.1);
Because you defined the line to print on (the number after kUser_Line1, x), you don't need the /n to go to the next line (I think). This may need confirmation. Good luck :D
Unread 08-02-2013, 09:58
kenfox kenfox is offline
FRC #3322 (Eagle Imperium)
kenfox is a glorious beacon of lightkenfox is a glorious beacon of lightkenfox is a glorious beacon of lightkenfox is a glorious beacon of lightkenfox is a glorious beacon of light
Originally Posted by wag2625 View Post
dsLCD->UpdateLCD();
I haven't used the LCD yet, but it works by sending a big block of text that sets every character on the display. You don't want to include newlines (even if the LCD hardware handles them, it would mess up the position of the other text being displayed).
Your code will write "Message" on line 1 starting at column 1. If you run it again it will do the same thing. Maybe try something like this to see if it's updating:
dsLCD->Printf(DriverStationLCD::kUser_Line1, 1, "Time %8.3f", Timer::GetPPCTimestamp());
dsLCD->UpdateLCD();
Unread 12-02-2013, 15:46
FRC #2625
Thanks, we were able to debug the code with that
