Go to Post On a side note... "Think outside the robot." - I kinda like that. I'll have to use that in a meeting someday.... - Not2B [more]
Unread 07-02-2013, 15:55
Gadeer Zbedat Gadeer Zbedat is offline
FRC #1946 (Mishka Monster)
Gadeer Zbedat is an unknown quantity at this point
What is the c-Rio code in C++ language
Hey guys , I dont succes to upload the code to the robot . because it lacks the crio code file !!
can you give me it guys ?!!
or where can I find it :?!
please help me , because the bulding season is already to end !!
Unread 07-02-2013, 16:31
AKA: Brad
#0190 ( Gompei and the Herd)
Re: What is the c-Rio code in C++ language
I'm not sure exactly what you're asking, but for a C++ project named "CommandBasedRobot" the generated file that needs to be downloaded to the robot is in the:
C:\WindRiver\workspace\CommandBasedRobotTemplate\P PC603gnu\CommandBasedRobotTemplate\Debug
folder and is called "CommandBasedRobotTemplate.out". This is the file you need to add to the preferences in Workbench, then when you select First / Deploy from the menu bar, that file will be downloaded to the robot. After deploying, be sure to reboot.
Brad
Brad Miller
Robotics Resource Center
Unread 07-02-2013, 16:33
Ok , thanx a lot .
