Go to Post A problematic dynamic and culture becomes apparent when failure persists for such a duration and reoccurs so frequently that students begin to accept it as the norm, and never learn the proper way to do things. - sanddrag [more]
Unread 07-02-2013, 18:09
wickzam wickzam is offline
FRC #4591
wickzam is an unknown quantity at this point
Re: Help programming joystick buttons
Originally Posted by Joe Ross View Post
You can use the getRawButton method of the joystick class to get whether a button is being pressed or not.
We tried to use getRawButton in our code but every time we use it there is a problem.
if you could show us an example of a code using getRawButton that would be very helpful.
Unread 07-02-2013, 18:32
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
i dont get it. whats your problem
Joystick j = new Joystick(1);
JoystickButton a = new JoystickButton(j,1);
a.whileHeld(new YourCommand());
in command based or
if(j.getRawButton(1)){
do stuff
in iterative. both will run when A is pressed
Unread 07-02-2013, 18:38
What kind of problem?
Here is an example of using getRawButton to switch between tank drive and arcade drive when the trigger (button one) on the left joystick is pressed.
    public void operatorControl() {
        chassis.setSafetyEnabled(true);
        if (leftStick.getRawButton(1))
            chassis.tankDrive(leftStick, rightStick);
            Timer.delay(0.01);
        else
            chassis.arcadeDrive(leftStick);
Also, in your original code, your autonomous code won't run because autonomous is misspelled.
Unread 11-02-2013, 02:06
arithehun arithehun is offline
AKA: Ari Falkner
FRC #3024
arithehun is an unknown quantity at this point
Have you heard about command based programming? It is a lot cleaner and will help you avoid creating hundreds (okay, not hundreds) of "else if" blocks and actually set up a polymorphic structure and abstracting your code. It's a specifically tailored design pattern. It's probably too late now, but it's something you should consider next year: http://firstforge.wpi.edu/sf/docman/...tation/doc1297
