Go to Post Just once I'd love to see a team come out to the field and say " Team xxxx rejects our reality and accepts yours!" - Koko Ed [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 07-02-2013, 00:01
snowballz snowballz is offline
FRC #4808
snowballz is an unknown quantity at this point
Re: I need a flashlight for our bot
Yeah basically, so is there any restriction on how many lumens? And I tried photon cannon but could find anything
Unread 07-02-2013, 00:02
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
inkspell4 will become famous soon enough
Here is a whole thread about photon cannons: http://www.chiefdelphi.com/forums/sh...d.php?t=110946
Chesapeake Regional : 2013, 2012, 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
Unread 07-02-2013, 00:04
FRC #4808
Thanks you very much guys
Unread 07-02-2013, 00:06
dcarr's Avatar
dcarr dcarr is offline
#HoldStrong
AKA: David Carr
FRC #3309 (Friarbots)
dcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond repute
There are no rules on this. Just don't intentionally try to blind the other alliance drivers and you should be fine.
Team 3309
2016 Los Angeles Chairman's Award Winner
2016 Orange County Regional Winner with 3476 & 6220
Team3309.org
Orange County Robotics Alliance
Unread 07-02-2013, 02:31
Garrett.d.w's Avatar
Garrett.d.w Garrett.d.w is offline
Build Lead
FRC #2733 (The Pigmice)
Garrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to behold
I have one of these for working on my car.
http://www.maglite.com/maglite_pro_LED.asp
I tried using it as a potential photon cannon in the shop the other day and I think that it would work quite well. If you focus it, the spot of light is easily visible from 50 ft away in a variety of lighting conditions. (your results may vary )
Good luck
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
Unread 07-02-2013, 13:19
Orion.DeYoe Orion.DeYoe is offline
FRC #5413 (Stellar Robotics)
Orion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to behold
Originally Posted by Alan Anderson View Post
What you should use depends on what you want to use it for.
What do you want to use it for?
I think they're making a photon cannon...
Unread 07-02-2013, 19:30
As to that, I would suggest doing a simple test: have your drive team stand under the goal, about where the driver station of your opponents would be. If they can't see when the light is on and pointing in their direction, assume that you'll be blinding your opponents, which could fall under R08, part A of the blue box, which would cause a nice chain reaction leading to a redesign. Note that it doesn't have to be designed to limit vision, just used to, or just cause an unsafe condition. Get the light so that it doesn't blind the drivers, then have them go to their own station's distance and see if they can see it. Repeat until you get it aligned.
