Go to Post Part of Gracious Professionalism is the Professional bit. Doesn't matter if you're a volunteer or a staff member, a failure of this level in the real world would result in getting fired. - [more]
Unread 07-02-2013, 19:55
AKA: Brad
#0190 ( Gompei and the Herd)
Re: Scheduler.getInstance().run() throws a null pointer
Can you confirm that you aren't seeing the update?
Thanks,
Brad
Brad Miller
Robotics Resource Center
Unread 07-02-2013, 20:10
I see the updated WPILibJ plugins (version 429) when I reload the catalog
Unread 07-02-2013, 21:05
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Thanks,
Brad
are these WPIJavaCV updates or WPILibJ updates? WPIJavaCV never worked for me and theres no WPILibJ updates (all are version 2013.0.417)
Unread 08-02-2013, 08:13
AKA: Brad
If you look in this directory:
http://first.wpi.edu/FRC/java/netbeans/update/Release
you'll see the file updates.xml. That is the file that controls the update process and it should be at version 429.
The SmartDashboard also updated both in the NetBeans update and in the plugin update.
Brad
Brad Miller
Unread 08-02-2013, 11:08
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Brad
how do you download from there
Unread 08-02-2013, 12:30
There are instructions here: http://wpilib.screenstepslive.com/s/...elopment-tools
Unread 13-02-2013, 21:19
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Can someone outline the solution for this issue? We're encountering it as well, and tried what we read in this thread - restoring that autonomous example command, updating the libraries... any help would be appreciated!
2016: Lake Superior WFFA
