Go to Post I think a 100% student-run team is as good as a school taught by your peers. - [more]
Unread 07-02-2013, 21:59
yes yes is offline
FRC #2338
yes is an unknown quantity at this point
Rule G05 and Autonomous
3.2.2.1 G05
When placed on the FIELD, each ROBOT must be:
B. confined to its STARTING CONFIGURATION
So our strategy with Autonomous was that we would place the robot into the optimal shooting position and move it so that it touched the pyramid while gathering data from encoders. The encoder readings would then be flipped and used to move the robot back exactly to the optimal position.
We recently reread the rules and found out that Rule G05 might kill our entire beginning to Autonomous. Can anyone clarify whether we would be breaking Rule G05 with our strategy?
Thanks in advance,
Just another programmer from 2338
Unread 07-02-2013, 22:02
ekapalka's Avatar
ekapalka ekapalka is offline
FRC #3216
ekapalka has a spectacular aura aboutekapalka has a spectacular aura about
Re: Rule G05 and Autonomous
I sure hope this is legal :D It's an amazing idea!
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Originally Posted by yes View Post
3.2.2.1 G05
Thanks in advance,
All that starting configuration means is that your robot cannot be outside its own frame perimeter before the match, be taller than 60", and have a frame perimeter greater than 112".
1592(Student and Mentor) 2007-2012
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 07-02-2013, 22:04
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
When placing the ROBOT on the FIELD it is typical for teams to push it into proper position. However, to record encoder counts would require the robot to be running. This means you would have to wait for your robot to turn on before you can actually finish placing it. I don't think the field crew will like the possibility of how long your team could take to be ready for a match factoring in the ~25 seconds for a robot to be on.
Unread 07-02-2013, 22:06
Chris is me's Avatar
AKA: Pinecone
Confined to starting configuration doesn't mean you can't move, it means you can't expand out of the frame perimeter before the match starts (and you can't go taller than 60 inches before the match starts).
Unread 07-02-2013, 22:11
G05 is not the issue. G07, delay of game, would factor in, however. Robots that take too long to set up get disabled for the match.
BUT! I have a solution! Presumably, you will know (or can dial in) your optimal shooting position before competition matches begin. Some moving of the robot either manually or with the controls should give you an encoder count to move a certain distance. Namely, the distance between the pyramid and your favorite shooting spot. Input that value into your code as the distance to move, and all you have to do is remember to turn the robot on (and anything else on your prematch checklist).
Unread 07-02-2013, 22:17
ekapalka's Avatar
FRC #3216
Maybe you could record the data during the practice rounds and make sure that you start in that particular position at the start of the competition.
Unread 07-02-2013, 22:18
Kusha's Avatar
Kusha Kusha is offline
Crimpin' ain't easy
AKA: Kusha Gharahi
no team (Looking for a team)
Kusha is a jewel in the roughKusha is a jewel in the roughKusha is a jewel in the roughKusha is a jewel in the rough
This question seems like it would fit this thread, would a tape measure be allowed on the field?
https://kusha.me
Unread 07-02-2013, 22:20
dodar's Avatar
No measuring devices are allowed on the field by team members.
Unread 07-02-2013, 22:29
XaulZan11's Avatar
XaulZan11 XaulZan11 is offline
AKA: John Christiansen
FRC #1732
XaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond repute
Send a message via AIM to XaulZan11
Unless it is part of your robot, right?
Unread 07-02-2013, 22:35
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
Yes, but...
Not strictly true, this year.
Originally Posted by Game Manual
3.2.2.3 G07
TEAMS may not cause significant or repeated delays to the start of a MATCH.
TEAMS are expected to stage their ROBOTS for a MATCH safely and swiftly. TEAM efforts that, either intentionally or unintentionally, delay the start of a MATCH will not be tolerated. Examples of such delays include, but are not limited to:
A. Use of alignment devices such as templates, tape measures, laser pointers, etc. to precisely place and/or align the ROBOT.
B. Late arrival to the FIELD.
C. Being indecisive about where/how to position a ROBOT.
D. Installing BUMPERS, or any ROBOT maintenance or assembly, once on the FIELD.
[Blue text represents the blue box in the rules; emphasis mine]
So, you can use a tape measure if you're quick about it. "Significant delay" is at the discretion of the Head Referee, so you'd better be careful. You might be able to find something faster (and more discrete) than a tape measure. For example, get a piece of string and tie knots in it at your desired distance from some reference point. That way, you'll be able to position your robot quickly and consistently, without getting penalized for delay.
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
Unread 07-02-2013, 22:38
MARS_James's Avatar
MARS_James MARS_James is offline
Always Scouting
AKA: James Comstock
FRC #0179 (The Children of The Swamp)
Team Role: Tactician
MARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond repute
Send a message via AIM to MARS_James
be taller than 60", .
Starting configurations definition says nothing about height and considering starting in your own Auto Zone you can be the max height of 84in
Driving Record: 24-8
Coaching Record: 66-31
2014 South Florida Regional Woodie Flowers Finalist
Unread 07-02-2013, 22:39
~Cory~'s Avatar
~Cory~ ~Cory~ is offline
Student
AKA: Cory Rypkema
FRC #0706
~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold
Correct, provided you can set up your robot just as fast as all of the other teams. We had a couple of "sighting" holes on our robot last year for starting position and the refs had no problems with us using them.
I am not sure about the legality of this tatic, but the robot could be turned on in the que and you could press a button to start "recording" the encoders when the bot is positioned on the field. Looking in the rules right now.
corin.rypkema.org
WPI Class of '17
'12 Dean's List Finalist, Mentor of 706 - Cyberhawks
Unread 07-02-2013, 22:51
Saberbot's Avatar
Saberbot Saberbot is offline
Ask me about Glentite™
AKA: David Ingraham
FRC #4146 (Saguaro Sabercat Robotics)
Saberbot is just really niceSaberbot is just really niceSaberbot is just really niceSaberbot is just really nice
Last year our alignment jig was my left shoe. It doesn't have to be too complicated!
Unread 08-02-2013, 08:46
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
This autonomous strategy is inherently outside the intent of the rules. The robot would get live calibration data prior to every match to use during the match? Yea, that ain't gonna fly. It's comparable to your drivers controlling the robot prior to autonomous period. It'll also set a precedent that will lead to wonkier rules about what's allowed to happen when a robot is set down on the field.
There's a better way: find a known point to always set down on, then go a known distance in autonomous. If you can't even do this, then your team will be in trouble if you're ever asked to move your starting position in order to accommodate another team's autonomous (e.g. you both shoot 3 from the same spot -- who moves?).
GitHub
