Go to Post I am a 2-3 year competition veteran, and a new member at chief delphi, and everyone here seems to be as nice as they are at the competition. Very gracious, you might say. - Ian S. [more]
Unread 07-02-2013, 23:01
ILikePizza555's Avatar
ILikePizza555 ILikePizza555 is offline
AKA: Isaac Avram
FRC #2761 (CN Ironhorse)
ILikePizza555 is an unknown quantity at this point
Re: CAN Encoder Programming problem
Originally Posted by Alan Anderson View Post
On the sensor, I see six wires: two red, two white, and two black. On the Jaguar, I see five: one each of red, white, and black, and two gray. What happens to the wires between the two devices?
You apparently have something connected to the "I" (index) pin of the Jaguar's encoder input. A signal on that pin will reset the count. Try just removing that connection and see if the count starts doing what you expect.
The wire leading that plugs into (-) on the Jag gets split into two and goes into gnd and Csn on the encoder.
PONIES ARE STOOPID MAGIK -Heavy
