Go to Post "FIRST" is not a verb (yet - give us time, and we will see what happens). - dlavery [more]
Unread 07-02-2013, 23:26
akash992391 akash992391 is offline
AKA: Akash
FRC #4684
akash992391 is on a distinguished road
error message on LabVIEW
hii i am new at LabVIEW programming like we are rookie team i need help with an error message can u please help me everytime is keep coming this message
Unread 07-02-2013, 23:59
Re: error message on LabVIEW
Did you successfully run the cRIO Imaging Tool?
Unread 08-02-2013, 00:00
AKA: Akash
FRC #4684
Yeah I did....
Unread 08-02-2013, 07:14
In the LV project window, midway down the window will be a line RT CompactRIO Target (10.xx.yy.02). If the xx.yy isn't your team number, then you need to set that. To set it, Right click on that line and choose properties. In the dialog that opens, update the IP address to include your team number.
Greg McKaskle
Unread 08-02-2013, 08:47
Also, run your Driver Station making sure to add your team number on the Setup tab. That'll set your Driver Station IP to match your cRIO.
