Go to Post As usual, I mistakenly look for a technical solution to a social problem. - MrForbes [more]
Unread 07-02-2013, 10:46
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Labview and AM magnetic encoder
Can anyone provide Labview help with interfacing with this encoder:
http://www.andymark.com/FIRST-Choice-p/fc13-062.htm
How do I wire it up and access it in Labview ?
Thanks
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 07-02-2013, 11:06
Re: Labview and AM magnetic encoder
I haven't used it, but I suspect that two ways to interface to it, are to
  1. Treat it like an incremental encoder and use the LabVIEW functions for that
  2. Average the PWM signal and treat it like any other analog input. See 7.4 Analog Output
You can send AndyMark the question and they can probably get you started.
Unread 07-02-2013, 11:46
There is an example built into LabVIEW.
Unread 08-02-2013, 00:01
http://wpilib.screenstepslive.com/s/...control-system
