Go to Post Sometimes i wish the robot could fit into my pocket. - GMAdan [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 08-02-2013, 02:36
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Using google documents to scout?
Originally Posted by dcarr View Post
How does that work...aren't WiFi access points prohibited?
Not Wifi. WiMax. Different frequency. And that's only for the internet connection. Locally, we run strictly wired networks. No wifi is enabled on any device.
Unread 08-02-2013, 02:39
dcarr's Avatar
dcarr dcarr is offline
#HoldStrong
AKA: David Carr
FRC #3309 (Friarbots)
dcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond repute
I got that part. I thought you were making a WiFi access point from your WiMax connection (but now I realize you must be running all Ethernet from that router).
One cool feature I've learned about DD-WRT - I have an Asus router at home with USB ports, and it allows you to use those to share the connection from a USB 4G device. Potentially opens up a lot of options in terms of '4G routers.'
Team 3309
2016 Los Angeles Chairman's Award Winner
2016 Orange County Regional Winner with 3476 & 6220
Team3309.org
Orange County Robotics Alliance
Unread 09-02-2013, 09:21
ctccromer's Avatar
ctccromer ctccromer is offline
Animus
AKA: Tucker Campbell
FRC #3753 (Bulah Bots)
ctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to all
So after playing around with forms on google documents, I'm 100% sold. It's like it's MADE for FRC scouting
A few questions:
1) If I send a form to someone, can they fill it out MULTIPLE times? (i.e. for each match) or do I have to send it to everyone before each match?
EDIT: Found out, yes they CAN fill it out more than once.
2) Is there any way to split the results up by a certain result? Like instead of one giant spreadsheet, is there a way to make it turn into a spreadsheet for each FRC team?
3) Is there any way to change the theme/background? The defaults are okay but I think it'd be cool to put our team logo on there
Thanks to everyone for the help! I'm very excited now
Team 3753 BulahBots
Unread 09-02-2013, 20:52
saikiranra's Avatar
saikiranra saikiranra is offline
UCI
AKA: Saikiran Ramanan
FRC #3476 (Code Orange)
saikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond repute
There are ways of splitting results, you need to use pivot tables or/and some semi-complicated equation like things. Making a sheet for every team is do-able, but we decided against it last year, because we attend the LA Regional, with over 60 teams.
I don't believe that you can change the back ground. We found the default easy to work with and we organized the rows by light blue and light red (for the different teams).
As for forms, we have had trouble last year using it. It worked perfectly before the competition, but they submitted too slowly and sometime did not submit at all. They might have fixed it since, but manually inputting the data works well too.
Again, Google Docs is one of the best things to scout with. It is so easy to use and it allows all teams to have the potential to make a great scouting system.
2014 - Current: Team 3476 Electronics, Programming, and Scouting Mentor
2011 - 2014: Team 696 Student and Drive Coach
[IMG] code is Off
