Go to Post Begging, yelling, kicking, and screaming for members of my team to send me updates while I'm at college not doing homework. - Ginger Power [more]
Unread 06-02-2013, 23:32
dchartley dchartley is offline
FRC #3684
dchartley will become famous soon enough
Re: How to change angle of shooter?
Here is a vid of our first test run on the chassis. Frisbee shooter works fine and the elevation adjustment runs off of a jack screw powered by a window motor. Used a couple of basic door hinges so that the angle of the motor and screw can change freely.
Doug
http://youtu.be/fuEmQBhBpnw
Unread 07-02-2013, 12:32
BurkeHalderman's Avatar
BurkeHalderman BurkeHalderman is offline
Casual Robot Observer
BurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant future
We're using a single air cylinder mounted on the side of the shooter to switch between being level (loading angle) or shooting angle, probably around 35 degrees. To fine tune the shooting angle we're using a magnet on the cylinder to adjust the stoke length.
A fairly simple solution
[2010-2014]: FRC 3266 Robots-R-Us: Founder and Alumni
2010 (5-5-1): Buckeye Regional; Driver
2011 (4-5-0): Buckeye Regional; CORI; CAGE Match; Drivetrain/Manipulator Operator
2012 (7-13-0): Buckeye Regional; Queen City Regional; CAGE Match; BPRC; Drivetrain Operator
2013 (25-15-1): Queen City Regional; Buckeye Regional; Crossroads Regional; CORI; Ohio State Champs; CAGE Match; BPRC; Drivetrain Operator
2014 (21-10-0): Crossroads Regional; Queen City Regional; Designer; Mechanical/Design Mentor
Founding an FRC team as an 8th grader sure wasn't easy, but it was totally worth it.
Get in touch with me:
Personal Facebook
I believe every human has a finite number of heartbeats. I don’t intend to waste any of mine. – Neil Armstrong
Unread 07-02-2013, 13:34
Bstep's Avatar
Bstep Bstep is offline
FRC #1983 (Skunkworks Robotics)
Bstep is a glorious beacon of lightBstep is a glorious beacon of lightBstep is a glorious beacon of lightBstep is a glorious beacon of lightBstep is a glorious beacon of lightBstep is a glorious beacon of light
Could someone please explain how a magnet can be used to adjust the stroke length of a pneumatic piston?
Thanks
Unread 07-02-2013, 14:45
G Fawkes G Fawkes is offline
FRC #1290
G Fawkes is an unknown quantity at this point
Doug
How did you connect the lead screw to the window motor?
Si Se Puede
Unread 07-02-2013, 14:54
I believe there are different kinds of switches that can be used to adjust the stroke of an air cylinder. The method that I was referring to uses a sensor that can be adjusted along the body of the air cylinder.
This works because the sensor detects a magnet on the inside of the cylinder, once the rod has extended to the desired position the sensor will send a signal which will limit the stroke to that postion.
More information can be found here :
http://www.bimba.com/products-and-ca...?searchRef=yes
Personal Facebook
Unread 07-02-2013, 15:44
JohnFogarty's Avatar
AKA: @doctorfogarty
I know for a fact our team is mounting the front end of our shooter on a bar as the pivot point and then the back end will be sitting on a CAM. Which will allow us to change our angle.
John Fogarty
Former Student & Mentor FLL 1102, FTC 1102 & FTC 3864, FRC 1772, FRC 5632, FRC 4901
Unread 07-02-2013, 16:01
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Originally Posted by kingbrandon14 View Post
We are planning to use an igus lead screw (picture above) attached to a strong motor to move the front end of the shooter up and down. We are still debating whether we should have two of these mechanisms (one on each side), or just one.
Another idea is to use pneumatics, but the disadvantage of that is there are only 2 positions: all the way up, and all the way down.
We have a lead screw being used to adjust our shooter mechanism, which for the most part, is working like a charm. I cant believe the 1st banebot gearbox ratio we chose was the best one.
Initially after the shooter was built, we mounted it to a varying angle extruded aluminum frame to match the height where we designed the shooter to be. From there we determined the optimal angle range of the shooter head. Thus, the decision to design a varying angle shooter using the lead screw was determined.
Unread 07-02-2013, 17:01
2348humanplayer's Avatar
2348humanplayer 2348humanplayer is offline
BIGGEST FRC NERD EVAR!!!!
FRC #2348 (The Cool Geeks)
2348humanplayer is an unknown quantity at this point
I'd suggest a cam. Basically an offset disc to transform rotational to linear motion. It's compact, and works smoothly.
2000 Silicon Valley Regional
2001 Silicon Valley Regional
2002 Silicon Valley Regional
2002 Championships
2003 Silicon Valley Regional
2008 Hawaii Regional
2010 Hawaii Regional
2011 San Diego Regional
2011 Hawaii Regional
2013 Hawaii Regional
2014 Silicon Valley Regional
Green = Spectated
Blue = Competed as Human Player
Teal = Competed as Coach
Lime = Volunteered at Regional
Unread 07-02-2013, 17:09
jasp's Avatar
jasp jasp is offline
AKA: jade
FRC #2537 (RAID)
jasp is an unknown quantity at this point
you could use a screw attached to an encoder to change angle. I would only use pneumatic if you are using pneumatics for something else on your robot because they are very heavy.
software is not magic
Unread 07-02-2013, 18:00
FRC #3684
We took the black plastic splined connector that came with the motor and glued in the jack screw using JB weld. Took some attention to keep the joint symetrical. The window motor seems to be geared just right for this application.
Doug
Unread 08-02-2013, 11:06
FRC #1290
Doug
Thanks for the quick reply.
How do you keep the black connector on the window motor?
Si Se Puede
Unread 08-02-2013, 16:12
capnslow capnslow is offline
FRC #3131
capnslow is an unknown quantity at this point
Last year we did something very similar with a window motor. We used a screw through the plastic connector and into the window motor shaft. However, you have to be careful because last year we had continual problem with pulling the metal cover off of the window motor because it's only crimped on and we were pulling with the screw.
Unread 08-02-2013, 16:32
FRC #3684
We use the force of gravity. The shooting platform weighs enough to hold it down. We had thought about using a bungee but that wasn't necessary.
Doug
Unread 08-02-2013, 16:47
jp1247's Avatar
jp1247 jp1247 is offline
No the cRio does not like aluminum!
FRC #1247 (ROK BOT)
jp1247 is an unknown quantity at this point
Not entirely true. I spent last weekend testing the plausibility of pneumatic angling. By using a dual solenoid, and 1 spike controlling it, im able to get infinite variation with no lack of strength.
The solenoids two red leads go to M+ and M- of the spike, the black going into a splice on the ground side of the spike. By setting the the spike to full forward (12 volts on both pins, 0 pot. difference) the cylinder hold position due to equal pressures. I can then simply set the spike to forward or reverse to raise and lower the piston, having it default back to holding. On a 1"" bore bimba piston, i cant move the shaft at all. Flow control valves on the piston allow me to control how fast it moves up and down.
I may link a video if i get the chance on sunday...
"No, you can't use the Kinect to do pelvic thrusts."
Unread 09-02-2013, 20:35
Negative 9 Negative 9 is offline
FRC #0611
Negative 9 is an unknown quantity at this point
Originally Posted by ksafin View Post
Well we ended up using a car jack that we motorized with a BAG Motor & VersaPlanetary box.. works pretty well; video here:
http://www.youtube.com/watch?v=GrscT...ature=youtu.be
What did you use to get the motor onto the end of the screw of the car jack?
