Go to Post Holy 5-year-old-thread-revival Batman!! - Mr. Freeman [more]
Unread 22-01-2003, 11:28
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
Pneumatic Connectors.
IMHO the rules concerning pnuematics are to limiting. According to the rules we can only use the parts in the kit. Which would mean that the connectors we are allowed to use are only those found in the kit. But there are a few parts that should be in the kit but aren't. What if i needed a simple brass elbow connector. or a Female to female adapter. These aren't in the kit.
Does anyone else think this is kinda screwy...limiting the connectors...
Some of the parts are also tricky to mount...like panel mounting the gauges...we figure glue is the easiest way...
Am i just interperting the rules wrong?
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 22-01-2003, 17:29
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Yes, they are rather restrictive, but that's the way it has always been. As for the brass elbow, you can always use a "T" and plug one of the holes. Between the hose and the brass fittings, I'm sure you can find a way to make just about anything work.
Unread 22-01-2003, 19:00
Moshingkow Moshingkow is offline
Moshingkow is an unknown quantity at this point
Theres really no point to an elbow connector in pneumatics, just use a hose...
Unread 22-01-2003, 20:22
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
You could try to use only brass fighters i guess
shaft connectors gail OCCRA 1 25-10-2003 16:07
Slip connectors (custom electrical connectors) Damian Manda Electrical 2 08-02-2003 17:53
Diagrams for wiring of 15 and 25 pin connectors archiver 2000 2 23-06-2002 23:03
RJ-45 connectors, DB25 connectors and the like: legal or no? Andrew Wyatt Technical Discussion 6 04-01-2002 22:53
45 or 75 amp anderson power products connectors to drill motors? Andrew Wyatt Motors 2 20-12-2001 08:00
