Go to Post Nobody has ever complained that someone was too willing to share their knowledge of building robots or their new ideas for anything. - Josh Hambright [more]
Unread 08-02-2013, 12:06
Arrowhead Arrowhead is offline
AKA: Daniel Brown
FRC #1369 (1369 Minotaur)
Arrowhead is an unknown quantity at this point
Programming Vex Motor Controller 99
So our team is using a small vex motor, and as a result we are using a vex motor controller 99 to control it. Can we get any help with how to program this?
Unread 08-02-2013, 12:51
Re: Programming Vex Motor Controller 99
The input timing for the VEX 29 controller are very similar to the Victor. You should be able to use the Victor class.
Unread 08-02-2013, 12:52
AKA: Daniel Brown
Ok thanks, ill try it out in a sec
Unread 08-02-2013, 15:54
AKA: Daniel Brown
The victor class doesnt seem to be working
Unread 08-02-2013, 15:55
At all? Have you installed the servo jumper on the PWM port you have connected the controller to?
Unread 08-02-2013, 15:57
AKA: Daniel Brown
We havent done, that, we are currently looking around our electronics bin for a jumper
Unread 08-02-2013, 16:02
AKA: Daniel Brown
We found a jumper on a old digital sidecar, and now everything is working
thanks
