Go to Post ...many different kinds of students join our team. Some only have an interest in media, or others in cheering. What is important is that they are having fun while working in an engineering environment. - Bharat Nain [more]
Unread 31-01-2013, 20:58
lscime lscime is offline
AKA: Luke Scime
FRC #2614 (Mountaineer Area RoboticS (MARS))
lscime is a splendid one to beholdlscime is a splendid one to beholdlscime is a splendid one to beholdlscime is a splendid one to beholdlscime is a splendid one to beholdlscime is a splendid one to behold
MARS 2614's Practice Robot Nearing Completion!
Since 2011, MARS has built its practice "beta" robot slightly ahead of schedule of the construction of its competition "alpha" robot (allowing us to identify issues and fix them before construction the alpha robot). This year's beta robot is taking shape and is (almost) ready for a weekend of testing and improvement!
https://www.facebook.com/photo.php?f...type=3&theater
Some Details:
-Dropped center 6WD, 2-speed transmission geared for 5ft/s and 17ft/s.
-2 wheel linear shooter.
-360 degree rotating and tilting turret.
-Load disks from feeder station, YES.
-Floor pickup, YES.
-Fit under pyramid, YES.
-Level 1 hang, YES.
-Level 2 hang, HOPEFULLY (it's designed but we won't know for sure until we do some more testing ).
Good luck to everyone!!
Unread 31-01-2013, 21:09
Re: MARS 2614's Practice Robot Nearing Completion!
I'm digging the colsons. Looks like some of the northeast teams rubbed off on you.
Stoked to see video of this soon, looks to be another effective design from MARS.
Unread 31-01-2013, 21:17
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
Are those 8 inch Colson's? O.O
This is a very pretty bot, though I still don't see the frisbee pickup or shooter. I guess that's all in construction? Can't wait to see it run!
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 31-01-2013, 21:31
AKA: Luke Scime
The Colson's are 6 inch. This is the first year we're using them and we're excited to try them out at competition!
Correct, the shooter transmission and wheels are not yet mounted and neither is poly cord or the front part of the floor capture device which makes it kind of hard to see those subsystems in the picture. You can see them in the CAD though (you might have to squint to see the shooter wheels hiding behind the shooter rails in the CAD )
Unread 31-01-2013, 21:35
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Looks great!
It's a bit hard to tell, but it doesn't look like there's enough space for four frisbees in the ground pickup. Is there some way that frisbees are fed back into the human load chute on top?
Unread 31-01-2013, 21:44
escime's Avatar
escime escime is offline
Earl Scime
FRC #2614 (MARS)
escime is a name known to allescime is a name known to allescime is a name known to allescime is a name known to allescime is a name known to allescime is a name known to all
Well, we have to leave something to mystery. We can pick up four frisbees
Unread 31-01-2013, 22:37
Garten Haeska's Avatar
Garten Haeska Garten Haeska is offline
AKA: Garty
FRC #2861 (Infinity's End)
Garten Haeska has a spectacular aura aboutGarten Haeska has a spectacular aura about
The turret tips down and the frisbee is put into the same chute that it will fly out of?
"Sometimes the questions are
complicated but the answers are simple."
- Dr. Seuss
Unread 01-02-2013, 00:04
Andrew Zeller's Avatar
Andrew Zeller Andrew Zeller is offline
Mechanical Engineering at UA
FRC #1716 (Redbird Robotics)
Andrew Zeller has a spectacular aura aboutAndrew Zeller has a spectacular aura aboutAndrew Zeller has a spectacular aura about
I agree with this. It appears that the turret would turn 180 degrees from its position in the CAD render and then would tip to allow frisbees to directly enter the shooter barrel from the intake. I am still puzzled as to how it can hold 4 frisbees between the intake and the shooter.
The intake is interesting, because it appears that frisbees would slide onto that plate for a few inches before contacting the roller.
Can you provide any details regarding the wheel mounted between the shooter and the frisbee hopper? Could this be part of your level 2 hanging mechanism?
FIRST ROBOTICS TEAM 1716 Redbird Robotics
2012 Wisconsin Regional Judges Award
2012 Wisconsin Regional Quarterfinalists
http://www.frc1716.org/
Unread 01-02-2013, 02:08
AKA: Luke Scime
You are correct about the shooter tipping down in order to receive ground disks from the capture device. The Frisbees then travel to the rear of the shooter where a mechanism (which you can't really see) loads them up into the the hopper. As you might imagine there are quite a few moving parts to the ground pick up system and in general we plan to load from the feeder station. The ground pickup capability is mostly for autonomous.
I believe you are seeing the wheels which help feed the Frisbees down from the hopper into the shooter (similar to the wheels on Robot in 3 Days).
Unread 01-02-2013, 02:15
DampRobot's Avatar
Physics Major
AKA: Roger Romani
I just love that time of year when I get to see what cool designs other people have been working on...
I was especially excited to see the intake. Besides the obvious (climbing), pickup of frisbees is the most chalenging part of the game. It looks like you've found a solution that works for you, we just never found a way to pick up frisbees that was satisfactory fo us.
Good luck with your season!
-Plutarch
Unread 01-02-2013, 07:56
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
Looks fantastic. I was especially taken with the idea of using the shooter elevation actuator as your level 1 tower lift.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 08-02-2013, 00:59
AKA: Luke Scime
Update:
This past week was mostly spent working out kinks and bugs, iterating some designs, and implementing those changes as the the alpha robot went into production.
(Apologies for the poor video quality)
Loading the shooter via a full magazine was tested (although the code for the fully automated sequence is not yet complete).
https://www.facebook.com/photo.php?v=564421343568944
The first successful level 1 hang was completed (it is fully off the ground in this video but we are missing a disproportionate amount of weight in the front so in the final iteration the hang will be much more balanced).
https://www.facebook.com/photo.php?v=564414033569675
The latest iteration of the floor grabber was tested (we understand what changes we have to make to get the Frisbee to more reliably travel up the rest of the feed system).
https://www.facebook.com/photo.php?v=564439130233832
The alpha frame is back from being powder coated and was stuffed with electronics last night.
And here is a slightly updated CAD render (the biggest difference is the new level 1 hook design)
We have also tested feeding the Frisbees backward through the shooter and into the breech and of course the pan and tilt functionality of the turret has been tested (sorry, no video at the moment but I'll try to get that up over the weekend). Additionally, excellent progress is being made on the level 2 stage of our hanging mechanism.
Unread 08-02-2013, 01:29
AKA: noops
That floor intake is very similar to ours. I have a quick question though. What we're finding is that with our system, an upward force is placed on our intake system when the frisbees attempt to enter and angle upwards in the intake system. How are you guys absorbing that force?
(The idea behind the force from what I understand is that the frisbee is not compressible, and you can only rely on friction to bring it in. )
Unread 08-02-2013, 13:45
escime's Avatar
Earl Scime
FRC #2614 (MARS)
The upper roller on our system is pretty robust, so even if the frisbee forces it upwards, and off the floor, it doesn't bend. The shallower the angle, the better of course.
Mountaineer Area RoboticS (MARS)www.marsfirst.org
2016 Palmetto Chairmans & Finalists & GP// GPR GP//SMR Finalists and Industrial Design //Newton GP
2015 GPR Chairmans & GP//SMR Champions & GP//Hopper Finalists
2014 SMR Chairmans & Champions & Entrepren. & GP & Dean's List// Palmetto Finalists & GP & Xerox Creativity
2013 SMR Engineering Inspiration & Entrepreneurship // PIT Entrepreneurship & Dean's List
2012 PIT Champions // NC Chairmans & Finalists // PIT Rockwell Controls Award // CMP Woodie Flowers Winner
2011 PAL Engineering Inspiration // PIT Entrepreneurship & Woodie Flowers Finalist
2010 NC Eng. Insp. & Rockwell Controls & Coopertion Award //PIT Rockwell Controls Award // CMP Dean's List
2009 PAL Rockwell Controls// PIT Rockwell Controls
2008 PIT Rookie All-Star // PIT Regional Champions
Unread 08-02-2013, 14:22
Orion.DeYoe Orion.DeYoe is offline
FRC #5413 (Stellar Robotics)
Orion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to behold
Thumbs up Re: MARS 2614's Practice Robot Nearing Completion!
Some Details:
-Floor pickup, YES.
-Level 1 hang, YES.
Great robot! Your floor pickup roller system seems to work similar to ours.
I can't wait to see you guys at Pittsburgh!
